Agreed I did go over everything I did on that day... Several times
( Really just cleraned things up a bit ..
Starting out this is a 84 Deville Limo
Overall car is in Great working order just had no heat and found a bad vac valve that would not mover so replaced that and shes all good on heat. After starting the car The Fan comes on full blast and A/C compressor runs without cycling at all had to remove wires from compressor accumalator iced up within a minute or two!!!
I'm thinking the ECM may have died and would like to check out atleast to see if I have power going in to the ECM! Just nto all that Familar with the setup on this car mainly a Honda person myself...
The only thing I moved on the HVAC system was a wire comming out of the Fan control module that was wire nutted and screwed to the body so I ty wraped it up and installed a new connector. All other eletrical work was minor or not related to any factory systems....
Can I pull codes to determine what maybe going on???
I have noticed several others have similar problems with other models I'm assuming Cadillac used the same system in many other models...
Maybe just some test points I can look at or anything to see where My problem may lie???
Lastly Which is the best shop manual to purchace? Most detailed and useful???
THANKS for all input!!!!
