Hey everyone, first off, just want to thank you for all of the knowledge shared on the site. I have done some searching and found some wire schematics, but hoped someone might have some input.
2006 STS-V 4.4L w/Keyless Ignition and Passive Entry, but I believe the system is the same as 4.6L/3.6L.
The car hasn't been driven in a few months, but I have had a battery tender on it since parked, and I start it (with the tender unplugged) about once a month.
Yesterday when I went to start it, it was no crank/no click/no start. Battery voltage 12.9 and load tested in the 80% range. The door opens normally with the key fob in pocket, and all controls are normal upon entry. When I put my foot on the brake, normal "Press Brake Pedal and Push Start Button to Start" appears in IP. When I press Start, everything on the dash goes dark. No warning lights, no backlights. I do get the passenger airbag light cycle through its normal sequence. I believe the dome lights stay on though, as the driver door was open. Also, as soon as I press the start button, the peanut lights in the headlights come on and stay on just like they would if the engine was running. There is NO audible click from the starter solenoid (possibly not even starter relay, was too far away to tell) when start button is pressed. There was also no significant change in battery voltage when attempting to start. When I push the off button on the ignition, the twilight sentinel headlights/taillights come on for a few moments like they normally do.
I have heard that battery connections can sometimes get loose or that battery voltage could be an issue. I tightened both terminals at the battery (which were tight) and hooked a known good jump box to the battery as well to try again. With the jump box on, I registered 14.4V at the battery before starting. When hitting the start button, the voltage didn't drop any noticeable amount either. No change in symptoms. I turned the ignition off again and this time placed my key fob in the compartment inside the center console (tried both directions) and repeated test. No change. Finally, I placed the gear lever in neutral and repeated, and then park again and repeated. No change.
My next step will be to begin looking for voltage at the starter relay. Has anyone had experience with this situation on these cars? Any help is appreciated!
