1 - 9 of 9 Posts
99 STS
tried starting the car, engine doesn't crank, just a click from the starter. battery volts read 12.7 on the DIC. anyone have any ideas?
Check the cables for a clean tight connection. If they are OK, the battery probably has a dead or shorted cell. Have it load tested or just replace it.
1996 STS
Do the accesories run when the key is on the "on" position? I had a similar problem, but when I tried starting the car it shut off completely, had to d/c the neg. batttery cable and r/c again to get the same problem. It turned out to be a faulty pos. and neg. battery connection, (also dirty). Check that first, then you could look at the fuses.
99 STS
Discussion Starter #4 (Edited)
i took the battery out, took it to auto zone to have it load tested, it passed so i reconnected the battery tired starting it for the hell of it, it clicked a few more times then started. starter on its way out? :confused:
edit: the accessorys do run with the key in the on position
Could be the starter solenoid not engaging. If you're going to go in that deep you may want to replace the whole unit while you're there.
I would think the clicking sound IS the solenoid engaging. Maybe the starter itself is bad and won't spin. Before going into the starter, I'd swap the battery with a known good one from another car just for the hell of it. How old is the battery anyway?
2012 Mercedes E63 Amg Station Wagon
Sure Sounds like a dead spot on the starter. I had a car that use to happen too and I crawl under it and whack it with a large wrench and then the car would start. It would only happen when the starter would stop on that dead spot, kinda like russian roulette, lol.
99 STS
Discussion Starter #8
the battery is a year old. i replaced it last year with another delco battery. ill try swappin the battery tomorrow with the one from my fathers deville and see what happens. thanks
1 - 9 of 9 Posts
