No communication with Electronic Suspension Control, VCIM, EBCM, BCM (auxiliary), FPCM, TBCM
15K views 33 replies 6 participants last post by  petethepug
Have a new to me 2008 Escalade ESV AWD that I'm trying to troubleshoot some dashboard light on dash. I currently have these lights on the dash; check engine light, parking brake light, service braking system, service stabilitrak, ABS light and Airbag light. I hook up a scantool - Autel mk808bt trying to diagnose the problem and I'm getting No communication with ESC, VCIM, EBCM, FPCM, TBCM. I'm more concern right now with no communication with EBCM as that can be the reason why parking brake light and ABS light and stabilitrak lights are on. I cleaned the grounding wire near the brake control module to make sure that it is grounded. I unhooked the FPCM wires and the SUV didn't want to start, plugging it back on, the SUV started. So I know the FPCM is working, just no communication with ECM? Also i am able to drive the SUV around. I don't want to just buy a new EBCM until i can diagnose that it is actually broken since it requires programming. When I bought the truck, I didn't know the ECM was replaced. I only found that out when I hook up the scantool and it was showing up a different VIN # corresponding to a 2010 model Escalade ESV. The BCM is displaying the correct VIN# belonging to my truck. Can this be the reason why I'm getting no communication with the module listed above? I was able to drive the truck home after purchase, so it appears to be driving okay. only code for check engine light is p0108 MAP sensor, I replaced the MAP sensor, however, the code keep coming back.
Question:
1. Fuel pump fuse in engine compartment with key ignition to on position OR off position, test probe light did NOT come on, isn't this suppose to have power all the time?
2. Is there a common wire that turns on these no communication module resulting in no communication?
3. I didn't see a TCM. Looks like location of the TCM is right behind the ECM per manual, however nothing is there. But the scantool is showing TCM information. Maybe TCM is part of the ECM? The ECM has two big connectors.
Sorry for the rambling, hopefully someone can shed some light into this and point me in the right direction. So far, I went ahead and order a new PCM/ECM programmed for my vehicle since i live in a smog state and if ECU is displaying incorrect VIN, it will cause a problem.
#5 · (Edited)
That'll be great if you can do that. Thank you! Maybe it's grounded to the engine block? From my understanding after tracing the negative cable from the battery. The negative cable ground from battery to engine block and a smaller maybe 12 Gauge wire ground to the front chassis on the front right side. There is a strap that grounds the firewall to the rear engine block.
* The new PCM came in, I did the swap and the relearn key procedure. For some reason, I do not see my immobilizer light coming on. The SUV didn't start, but I continued with the procedure. After waiting 10 minutes, turned ignition to off, wait 5 seconds, turn ignition to ON, and NOTHING. At that point, I was worried. So I sat there for couple minutes browsing online regarding relearn instructions and I was just stumped as to why NO immobilizer light. Well, I tried to start SUV again and it turned over. :) The communication problems I have is still there, but at least now the scantool is reading the correct VIN number.
#15 · (Edited)
Here is the schematic for the HS buss. See if you can figure out where a bad connection would be to cause loss of communication with the modules listed above.
And yes, the resistance between 6 and 14 of the ALDL should be 60 ohms.
A quick study makes me think the problem.is in the left IP junction block.
And, I don't think your vehicle has the controller called out as BCM (Auxiliary)
#16 ·
Short in the left IP junction block? Can I jump the connection to test? Or pull junction block and test for continuity between certain pin? Also the diagram show a 120 ohm DLC resistor after EBCM and also after ESCM? I thought only two resistor, one internal to ECM and one after ESCM in this vehicle.
#19 ·
The XXX or -XXX is referring to an option in the vehicle. The 3 letters are the RPO codes of different options. If your vehicle has that option you follow the XXX lines. If you vehicle doesn't have that option You follow the -XXX lines.
In your example UE1 refers to "Communication System - Vehicle, G.P.S. 1"
You need to find the RPO code label in your vehicle. Then you can use that to determine which branchs of the schematic to follow.
As far as the open circuit goes.
If the buss is disconnected, as yours seems to be, the modules can't talk across the break but they can talk where they are still connected. The system acts like two seperate busses.
Thqt means that they can still function somewhat but not perfectly. Things are also designed to be robust enough the maintain some functionality even when broken.
#22 ·
That line denotes the two wires are a "Twisted Pair" when you find them in the harness you will see they have been twisted together. This is used in many low level signal wires to help with noise reduction. The also use this in unamplified audio signals and microphone signals for the same reason. If you need to replace any great length of CAN bus wires you should use twisted pair. I just put two wires in a drill chuck, put the other end in a vise and run the drill to twist them together.
#24 ·
First, find the RPO code sticker in your vehicle and verify if UE1 is listed on it.
Also do the same check you did for pin 6 of the ALDL for pin 14.
The VCIM is located in the center of the IP behind the HVAC control module. It has 3 connectors on it. X1 is white X2 is listed as natural, probably tan. X3 is gray.
#27 ·
Yes. I didn't have time this morning to reconnect everything so I wasn't able to test. It did solved the problem. No more lights on the dash. I had to remove the brake control module connection and reconnect it for it to work. Probably going to zip tie some of the connection so they're tight. Now onto the next problem. The transmission is not wanting to move forward. I don't have first gear. It's able to move in 2nd gear by either using a scantool to command it into 2nd or by removing the trans fuse. Any ideas? Should I start a new discussion?
#32 ·
Hey Man, glad you’re ok. Tech II says [emoji3] check for adverse interactions or possible side effects of any Rx you’re taking.
I was given given an Rx to control hypertension. 5 Mo later I felt weak and just not right. We have xlnt Ins so got checked out at ER. Docs kept telling me their equipment was not working. Turns out my potassium level was so low only the expensive lab equipment could verify I was ready to stroke out or start convulsing. It took two days of IV’s and potassium tablets to get back to normal and last two days in hospital had symptoms like DT’s without the benefits of being a drinker.
My doc told me to make a f/u Appt with him. I f’d up and did not. That almost killed or crippled me. If you can, run labs Mo’ly until you determine what’s up.
Merry Christmas [emoji320] and hope all is on the up and up.
Sent from my iPhone using Tapatalk Pro
#33 ·
I use to take meds for a while for panic attacks, don't know why I started to get them but it was a fact of life for a while. More than likely it was the prolonged stress of military life and deployments. I took them for years and then the doctor got me off of them when I retired. It's been almost 7 years since I took any and everything had been fine. I started back on a low dose just to get my body back to normal. Feeling much better and back on track.
