I replaced it with the original refurbuished(updated cd player) head unit from AJR,Mlps.MN. I looked thru the fuse info....3 fuses, one 10amp 12v continuse for clock and settings, one 10amp 12v inginition runs radio, and a 30amp runs Bose amps. In a 92 Eldorado the 30 amp tucked under the fuse cover in the engine compartment it's the fuse block next to the fuses you can get to. You have to take the brase strut off and the cover to get to it. Does the stereo still work if this 30amp is burned out just not driving the amps? I did not have time to look at it yet....running around picking up a recuvred, restored '70 hemi cuda distributor for a buddy with MS. Tonite? if someone doesn't tell me here not to waste my time telling me the stereo will not work if the 30amp is blown....
Guy
