My '03 sport has been great but with only 90,000km, I'm starting to get nickle-and-dimed.
Recently I had the engine light come on which the dealer has diagnosed as a faulty thermostat. This seems to be a fairly common 03 CTS issue and requires a fairly hefty charge primarily for the labor. (Obviously, something that must be fixed to avoid major potential damage.)
The drivers heated seat has failed, I'm assuming an "element" failure as it doesn't seem to be any of the fuses.
The radio reception has gone bad. As it is on both AM and FM, I assume it's not an antenae issue? Furthermore, the CD player has now jammed giving me a "mechanical" failure prompt. As a result I'm guessing that I need the entire unit replaced by the dealer?
Also a Service Stabilitrack prompt comes up randomly?
Aside from losing a tie rod last year shortly after exiting the highway, it's been a pretty good car. Currently just wondering if anyone has any words of wisdom (other than vaseline related comments) prior to handing it over to the dealer? (ie Is it an option to go with a newer radio/CD stack which has an IPod connection? Is there something else they should replace when doing the thermostat? etc...)
Thx in advance...
Thx in advance...
