Blue chip and fast. My .02 cents.
Hey luxThe problem would be that the whole car would have to get painted. The top part cannot be just masked off and have the bottom sprayed, it wouldn't match. You would have the get the entire thing painted for everything to match. At my old body shop, you'd be looking at around $2000.
I knew the whole truck would need to be painted. It it impossible to see in these photos, but the blue chip portion of the truck has some pin stripes on it as well. The problem is, is that the stripes are paint, not stickers. I'll post more photos later to try and show everyone.The problem would be that the whole car would have to get painted. The top part cannot be just masked off and have the bottom sprayed, it wouldn't match. You would have the get the entire thing painted for everything to match. At my old body shop, you'd be looking at around $2000.
The painted pinstripes, believe it or not, are the easiest to remove. Buy a small quart of laquer thinner from ace hardware or walmart. Get some on a rag and just rub it very gently. It should come off like butter, just use a little at a time. Follow up with a quick wax to the area you just cleaned, because the laquer thinner will wipe away any wax/protectant. The reason this happens is because the pinstripes are painted with a laquer base paint, and will not harm the factory finish because the clearcoat is not laquer based.I knew the whole truck would need to be painted. It it impossible to see in these photos, but the blue chip portion of the truck has some pin stripes on it as well. The problem is, is that the stripes are paint, not stickers. I'll post more photos later to try and show everyone.
Thanks for all the input!
It kinda looks like a cross with a Chevy Avalanche... it does not look bad I am just not used to seeing them like that! What size rims you got on there btw?
