Pulled the trigger, here it is:
2007 CTS-V Thunder Gray, really nice, 93k miles. A few issues I need help with.
1. There is a low pitch vibration only in 6th gear when you press on the accel pedal It does not occur in the other gears, but it is bat enough that the rear view mirror vibrates.
2. The steering wheel is off center on a straight road. I found the alignment procedure, and noticed a special tool A J 45845 which I think I can make but I need the recommended street alignment specs, which I could not find in this really great site. I have my own homemade alignment tools and I routinely align my Corvettes myself.. If anyone is interested in seeing my home made tools, PM me and I will send you the file, it is too big to upload on this site. You can measure camber caster, toe and rear thrust angle with the tools.
3. Owned by a smoker and the evap coil needs cleaning. Any suggestion on getting to the evap to clean it? I've cleaned up smokers before, but any advice would be greatly appreciated.
Thanks in advance for any help.
