1 - 20 of 22 Posts
2017 ATS-V Sedan
Hey All! I'm thinking of purchasing a 2013 ATS4 2.0T (performance package) that I test drove on Saturday, but the more lurking I do around the forum, the more nervous I'm becoming. Are reliability issues pretty serious with this year of the ATS? I seem to be reading about a lot of engine issues (primarily piston related i.e. blowing motors). Similarly, I'm hearing some horror stories related to the electricals. The particular vehicle I'm looking at is certified so the extended warranty lends some comfort, and after obtaining the services history it doesn't seem to have a scary background. So, big question is, if you could do it all over again, would you?
Noted service history:
Recalls
Product Safety Recall N140171 14171 LAPBELT PRETENSIONER LOCKING PERFORMANCE 11/03/2014 Closed
Noncompliance Recall N150119 15119 SUNROOF SWITCH MVSS 118 COMPLIANCE 02/24/2015 Closed
Service Update Bulletins N130013 13013 SUB: TURBO-TO-EXHAUST MANIFOLD JOINT MAY RELAX - * EXPIRES W/BASE WARRANTY * 01/24/2013 Closed
Product Safety Recall N140340 14340 INCOMPLETE WELD ON THE SEAT HOOK BRACKET ASSEMBLY 07/24/2014 Closed
Service Update Bulletins N140687 14687 SUB - INSTRUMENT CLUSTER INTERMITTENT OPERATION & RESET - * EXP W/BASE WARR * 04/13/2015 Closed
Product Safety Recall N140179 14179 AUTOMATIC TRANSMISSION SHIFT CABLE 06/16/2014 Closed
Customer Satisfaction Program N120293 12293 CUE SYSTEM UPDATE - * EXPIRES MARCH 31, 2015 * 02/21/2013 Closed
Service Update Bulletins N130059 13059 TRANSFER CASE OIL PIPE INSTALLED INCORRECTLY 02/27/2013 Closed
Customer Satisfaction Program N140591 14591 PISTON DAMAGE DUE TO ENGINE MISFIRE 12/09/2014 Closed
Service Update Bulletins N130198 13198 HVAC SERVICE PERFORMANCE 06/28/2013 Closed
Service Update Bulletins N130234 13234 SERVICE UPDATE BULLETIN - ROUGH ENGINE IDLE- * EXPIRES WITH BASE WARRANTY * 07/31/2013 Closed
Warranty Work
04/22/2015 63550 ZFAT----Field Action Recall 9100970 - N140591 - Replace Spark Plugs and Reprogram ECM with SPS 20,436 MI
04/22/2015 63550 ZFAT----Field Action Recall 9101211 - N140687 - Reprogram Instrument Panel Cluster 20,436 MI
04/22/2015 63550 ZFAT----Field Action Recall 9101289 - N150119 - Roof Console Accessory Switch Trim Plate Replacement 20,436 MI
04/22/2015 63550 ZFAT----Field Action Recall 9100813 - N140171 - Replace Both Front Seat Belt Tensioner Assemblies (inc. Deploy Pyrotechnic Devices) 20,436 MI
11/29/2014 542116 ZREG----Regular Vehicle Transaction 3423370 - Audio Disc Player, USB, Auxiliary In, and Memory Card Receptacle Replacement 16,682 MI
11/29/2014 542116 ZREG----Regular Vehicle Transaction 1421080 - Aero Shutter Front Bumper Fascia Air Deflector Replacement 16,682 MI
11/28/2014 542076 ZFAT----Field Action Recall 9100633 - N140179 - Inspect Transmission Range Selector Cable 16,619 MI
11/28/2014 542076 ZFAT----Field Action Recall 9100752 - N140340 - Inspect Left and Right Front Seat Mounting Hook Welds - No Repair Necessary 16,619 MI
11/28/2014 542076 ZREG----Regular Vehicle Transaction 0600513 - Cadillac Premium Care - Tire Rotation 16,619 MI
11/28/2014 542076 ZREG----Regular Vehicle Transaction 0600503 - Cadillac Premium Care - Oil Change 16,619 MI
06/06/2014 531571 ZREG----Regular Vehicle Transaction 0600513 - Cadillac Premium Care - Tire Rotation 10,442 MI
06/06/2014 531571 ZREG----Regular Vehicle Transaction 0600503 - Cadillac Premium Care - Oil Change 10,442 MI
01/31/2014 524705 ZREG----Regular Vehicle Transaction 0600513 - Cadillac Premium Care - Tire Rotation 6,114 MI
01/31/2014 524705 ZREG----Regular Vehicle Transaction 0600503 - Cadillac Premium Care - Oil Change 6,114 MI
08/02/2013 514252 ZFAT----Field Action Recall 9100113 - N130234 - Reprogram ECM 210 MI
07/01/2013 512176 ZFAT----Field Action Recall 9100082 - N130198 - Reprogram HVAC System Control Module with SPS 210 MI
03/11/2013 505359 ZFAT----Field Action Recall V2775 - 13059 - Inspect Transfer Case Oil Delivery Tube - No Further Action Required 48 MI
03/11/2013 505359 ZFAT----Field Action Recall V2773 - 12293 - CUE System Update 48 MI
01/28/2013 502944 ZFAT----Field Action Recall V2765 - 13013 - Tighten Exhaust Manifold Bolts 48 MI
01/10/2013 501758 ZPDI----Pre-Delivery Inspection Z6999 - PDI Related Fluid Adds 2 MI
12/21/2012 A48259 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 1 MI
Current 2014 red CTS Vsport/ Black Raven 2013 3.6 ATS4 gone
All look normal recalls and some little fixes. Tranfer case, Shutter replacement, not to bad. All looks pretty regular to me. Regular fixes and still under warranty.
none
Don't worry, half the engine issues on this forum are from one guy. I almost didn't buy mine because of him but so glad I did. My only issue so far is the moldy smelling AC. Besides that I love the car and very happy I made the purchase.
G
I see nothing major there it is mostly safety recall inspections and software reflashes.
Plus it already has the CUE customer satisfaction update.
ATS
2014 2.0T Luxury - definitely would do again - great car. And as was said above, the piston issues are way overemphasized on this forum. Search if you're interested, but be prepared to read a lot, some of it BS.
2013 ATS 3.6 AND 2012 SRX
Consider getting the 3.6 V-6. It howel's. If you want to make it better add the after market super charger (400 hp).
2014 Red Obsession ATS Premium 3.6L
if u live in cold climate (max temp at 80 or so), no worry about moldy ac.
Why take chances on the 2.0 (even though small possibility) if you can get a 3.6 that so far has not had any reported blown pistol (at least from this forum)? On top of that, the 3.6 feels and sounds more satisfying imo.
2017 ATS-V Sedan
Thanks for the responses, fellas. I was looking at the 2.0T only because that's primarily what's available around me in Denver. The particular vehicle noted above had an MSRP of $49,700 and with the 20,000 miles on the clock we were able to agree on a price of $31,000 out the door. It's pretty hard to pass up at that price. Figure a tune would keep me happy, powerwise. I'm coming from a 2006 H/C/I GTO, so I'm trying to calm the go-fast bug.
none now, but will look at CT5. 2017 Lincoln MKZ 3.0T. Former 14 ATS 3.6
I would definitely get my ATS again. I have had it for about a year and a half. Every car has a few bugs, and most get vastly overblown on forums like this.
As far as 2.0 Turbo vs 3.6, I thought the 3.6 ran better here in Ohio, but probably a different story in Denver. The turbo's forced induction will work better at altitude (thinner air) than a naturally aspirated larger engine. If I lived in Denver, I likely would have gotten the turbo motor.
2017 ATS-V Sedan
Discussion Starter · #11 ·
It's got the extended 6 year / 70,000 mile bumper to bumper as a CPO vehicle. My fear is the post warranty phase as I tend to keep my cars for a very long time. Between all of the electronics and the engine issues, I was hesitant. But I think I'll be pulling the trigger today. Deal is tough to pass up with the CPO.
hmm,.. I thought that the bumper to bumper only lasts max at 4 year /50k. Any "extended" warranty will have a long list of exclusion?
NONE
First of all, welcome aboard. I'm relatively new as well and this is a great message board.
I came from a 2011 Camaro SS. You will miss the LS motor every day. It's not so much the power, its the sound/feel of it. The 2.0t is a little "lawnmower-ish."
I'm fairly happy with mine. Based on my budget and needs I still think I bought the right car and if I could go back, I would probably do it again. That said, if I had a higher budget or was willing to spend more money on maintenance, I would have bought a 3-series.
2013 3.6 RWD Premium - 2006 BMW Z4M
'16 ATS-V Coupe "Arrest Me Red"
Had a 3-series, but bought a '13 V6 1 1/2 years ago. No issues, aside from one or two minor sensor things the dealer fixed for free. No moldy smell, either, and I live in Seattle. It's a fun, solid car- I'm really enjoying it. My only gripe is the depreciation, which you've wisely sidestepped ;-) Would definitely do it again, except maybe opt for a lease instead...
2017 ATS-V Sedan
Discussion Starter · #16 ·
Well, I had a deposit on the car and went to pick it up today after it was cleaned/detailed. One of the first issues I noticed was a rather significant gap between the hood and grill that I chalked up to the aftermarket grill not fitting correctly. But on second inspection today, the gap extended to where the hood and bumper should align. Rather than sit flush, I could actually fit my fingers between. Popped the hood again and upon closer inspection there was, what I believe to be, primer residue after sanding. Car checked out with both CarFax and AutoCheck, but I just had a bad feeling and walked away. You can actually see the gap in the photos the dealership posted. Looks like I'll keep looking.
http://www.autotrader.com/cars-for-...&mmt=[CAD[ATS[]][]]&listingId=398827325&Log=0
2019 XT4 Premium AWD Build 7/22/18 / 2013 ATS4 3.6 Premium Build 12/21/2012
Go with your gut because you don't want to be second guessing you decision. The right ATS will come along so don't give up keep looking. It really is an awesome car.
1 - 20 of 22 Posts
