1 - 8 of 8 Posts
She sits a bit above the first line above the middle of the temp gauge when driving and creeps over the 2nd nearly into the red in traffic...I am sure it is a coolant leak but I was wondering if there are any common leak spots on the N* motors? this is my first "modern" Cadillac and I don't know much about the motors and their problems...
Where do you smell coolant from? Near the engine area, or exhaust?
Have you checked fans for proper operation? They should go slow at around 5/8 (~224F) mark and go fast before 6/8 (~236F). It brings the temp down to middle (~213F) and turn off. They constantly run with any A/C operation.
Do you have proper coolant level? It is to the middle of the tank (about 2 1/2 inch down from the neck).
1996 Cadillac Seville STS
I had an issue similar as yours, so i had the coolant flushed by Chevy. I soon found out that I needed a new radiator so I changed the radiator and changed the rest of these for S&G's thermostat, water pump, upper and lower radiator hose. (consider changing the cooling temp. sensor while you’re doing the cooling system something I just replaced today "sucked".
Fresh Oil and good cooling system will keep this car on the road.
2006 XJ, 2000 Eldorado ESC--total loss :(
Usually around the water pump, either the wp seal, the cover gasket, the t-stat gasket, hoses, heater lines behind the engine, radiator side tanks, surge tanks.... any tell-tale white powder residue?
1993 Cadillac Eldorado Sport Coupe 4.6L Northstar "Y"
also wouldnt hurt pulling your dipstick and checking oil, make sure it DOESNT look like a chocolate milk shake:thumbsup:
checked the oil for coolant contamination and thankfully there is none.
For the record, a Northstar with failing head gaskets very seldom contaminates the oil with coolant or vice versa.
If you smell hot coolant, you do not have head gasket problems: you have a coolant leak, and the possibilities for locations are quite a few. It's gonna take some dedicated snooping on your part.
1 - 8 of 8 Posts
