Just installed Monroe 171685 Quick-Struts and MA822 Max-Air Shocks on my Deville. I took it for a three-mile trip and it rides a little bouncy. Is that normal for these shocks?
I wll be getting an alignment this weekend.
Also, I have a question about the holes on the Monroe brackets vs, the factory struts I took off. Both holes for the bolts on the factory strut are exactly the size of the bolt that holds the lower part of the strut in place. The top hole on the Monroe is the same but the bottom one is wider as if it were made to adjust in or out. I put it back as close to where I thought it was but wondered why they would do that unless it's to make the strut fit more than one vehicle.
I've attached an image I found that sort of shows the elongated lower hole.
If I didn't get it exactly right I'm assuming the alignment will fix that??????
thanks again for your help.
