New owner help needed 1991 Fleetwood Brougham radio/antenna no power
3.3K views 4 replies 2 participants last post by  DB2Guy
I just purchased a beautiful 1991 Brougham one owner with 7611 miles. It is in beautiful condition, however there is no power to the radio or antenna. No clock displayed. It appears that some one had worked on the antenna as the collar at the top of the fender is missing. I checked the radio fuse and it is ok. I have ordered the service manual to help with troubleshooting. Hoping someone here can share their expertise.
#2 ·
Did you remove the radio head and see if it is plugged in? On the '91 there are 2 components to the radio. The radio head that you see in the dash where you turn it on and set the radio station. Behind the dash to the left (drivers side direction) between the instrument panel and the radio is the amplifier/receiver unit. Another PITA to remove and put back in. Quite likely that is what is failing to work and not the radio head unit. I had to extract mine and have it repaired. I believe the radio head gets power from the amp/receiver unit. The antenna plugs into the amp/receiver.
The service manual tells how to remove and put back in the amplifier/receiver.
There is a power antenna relay on the relay panel. The owners manual should have the diagram. The relay panel is attached to the fuse block panel under the dash on the driver side on the firewall behind the parking brake.
Dear gawd don't pull the relay panel out because you will hate yourself. It is one PITA to put back in.
Right off hand I don't have that relay panel diagram.
#4 ·
Thanks. I have removed the radio head unit, but had to stop before digging deeper into the dash for the amplifier. I’m hoping that it is unplugged but I find it hard to believe the previous owner would have done that, especially with so few miles. I know electronics the issue isn’t miles but time so the amplifier may be toast from age not use. I have the service manual on order.
Thanks for the quick response and look forward to being able to contribute in the future on this board.
