1 - 13 of 13 Posts
Hey, I have a 2014 ATS 2.0L and I have a few questions. First one, what the heck with the mirrors on these cars? Both the drivers and passenger, the metal has literally turned to dust. I replaced the drivers already and now my passenger is doing it. Is there any way to just buy the metal base rather than replace the entire assembly?
I'm a bit ashamed to say this but I have no idea what model ATS I have. Luxury, performance, etc, I have no clue. How do I know? I want to do an add on subwoofer and amp and I don't know if I have the bose system. I suspect not, as I don't see anything saying I do. Should this be a fairly straight forward deal or am I going to run into issues if there's a factory amp already on board? I'll need to use a LOC to convert to RCA and I didn't know if it has a factory amp that would cause issues.
I appreciate any assistance.
You should be able to determine that from the RPO codes. There's a sticker with all of the codes used to build your car, usually in the trunk under the carpeted floor covering. Or, you can send an email to [email protected] with your VIN asking for a build sheet, which will include not only the RPO codes but what they mean as well. It's FREE, and you should get a response real quick, sometimes the same day. Here's a snippet from the wife's '13 ATS to give you an indication of what the build sheet will look like.
Font Screenshot Number Document Circle
2014 ATS 2.0T 6spd manual Performance RWD
For 2013-2014 I believe cars that don't have the LED DRL's are luxury trim. Cars that do have the LED DRL's are either Performance or Premium trim. For Performance/Premium if you look at the RPO plaque in your trunk, FE2 suspension code indicates Performance trim while FE3 indicates Premium.
Here is a thread on the difference between the headlights with LED DRL and without:
Led strip on the headlight
There are a couple threads on the sidemirror corrosion issue, here is one:
2016 ATS Premium 6-spd MT
Oddly enough, the 5th digit on my car is an H.
Crap. I had a MS Word document with all this laid out and explained, and I can't find the blasted thing! Yes ... I do recall an "H" in the fifth position but can't recall what that means.
EDIT: I believe that scheme I posted above refers to RWD vehicles only. That's all I was interested in when I researched for my car which absolutely HAD to have a 6-spd manual.
AWD vehicles have this code:
G=standard AWD
H=luxury AWD
J=performance AWD
L=premium AWD
Sorry about that. :oops:
Here is for the 2014 ATS
Font Material property Parallel Rectangle Screenshot
G=standard AWD
H=luxury AWD
J=performance AWD
L=premium AWD
Here is the 2016
Font Parallel Rectangle Number Diagram
1 - 13 of 13 Posts
