1 - 9 of 9 Posts
2000 eldorado
Hey guys, I just picked up a 2000 eldorado with 44k on the car. Really clean car, but I have a CEL. So I ran the codes and I'm getting 5 codes. If someone could please advise. Also, the car starts and runs good.
Codes:
P0135
P0340
P0341
P0135
P0340
I noticed that it repeated the last two, but my obII gave me those codes. Please advise on how to get this corrected by me. Thanks
:highfive: Welcome aboard !!!!
Now, go back to the "How to pull codes" sticky post and open the proper link to the Master Index of code definitions.
Come back and post the code, whether it's Current or History, and the definition of each. (We all have to do the same process - nobody memorizes all the hundreds of possible codes.)
(EDIT: You're looking for an O2 sensor in the top of the rear exhaust manifold [B1S1] as well as the CaMshaft Position sensor [CMP])
2000 eldorado
Discussion Starter · #4 ·
I tried pulling the codes, and apparently i could not understand how to pull the codes on the car: but i plugged in the OBII into the comp, and it showed me these codes...
Pending Codes:
P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1
P0340 - Camshaft Position (CMP) Sensor Circuit
Stored codes:
P0341 - Camshaft Position (CMP) Sensor Performance
MIL DTC
P0135
HO2S-11 (Bank 1 Sensor 1) Heater Circuit Malfunction
Here's the CMP and B1S1 - check the wiring harnesses and connectors first. B1S1 is unholy murder to change. CMP is held in by a short 10mm bolt. B1S1 takes magic and an O2 sensor split socket or crow's foot.
Talk to Chris up in RippyParts - Vendors - Cadillac parts man.
Don't know of a free GM manual site, but try www.alldatadiy.com. It's a subscription to the GM manual, all DTC's, RPO's, diagnostics, recalls, labor times, various specifications, workarounds, too much to list.
1 - 9 of 9 Posts
