2003 Escalade
Hello,
Recently I replaced my water pump, steering pump, motor mount, sway bar and linkage. Still there is a annoying sound that I get during acceloration. It sounds like a hissing air sound. Could I have messed up my intake seals or exhaust gaskets when I jacked it up to change the mount? or is there enough rooms to have the le-way to change the mount.
2003 Escalade
It sounds like it is right in front of the driver seat. I cannot even hear it if I am under the hood trying to listen. It could be an intake leak. Or exhaust leak. Can I check them my spraying something around the intake seals.
I've heard of folks using propene around the intakes to see if the cars revs will pick up (it would if its sucking propene thourhg a leak in the intake gasket) but I personally think its risk to be pouring flammable gas onto a running engine....
You can do this with with over the counter aerosols like throttle body cleaner. Spray Arround the mating surfaces of the gasket if a change in idle is noted, then you have a leak.
-The Cadillac Rancher
Sounds like a vacuum leak. Check the vacuum line on the parking brake release. Also check to see the the diaphram will hold vacuum.
2003 Escalade
how would I check the diaphram, and where is it located. I did find a plastic piece by the wiper are with hard plastic and two rubber fittings sitting there disconected.
