1993 sedan deville
For my FWD 93 sedan Deville.
I bought Monroe struts they were suppose to be a fit. well they fit and they are air struts, but they do not have the electrical sensor track connection. Is there a work around for this ?
I did watch a video that changed out for the same type strut. . That guy just cut and tied off the sensor wire. Is that ok ? and do I need to disable the ride sensor ?.
What do other people have to do with those connection when they eliminate the air ride all together?
1993 sedan deville
Discussion Starter #2
Ok no one wants to say. I don't know what they actually do but was told just to cut or tape them off. All is working fine. The sensor track shock struts are not available anymore.
IF your car originally had EITHER the SSS - Speed Sensitive Suspension -
OR the RSS - Road Sensing Suspension -
the struts and shocks had 3 settings and were automatically - electronically adjusted -
SOFT - slow speeds or rough pavement -
MEDIUM - between SOFT and FIRM -
FIRM - highway speeds on smooth/level pavement -
even when working properly - the difference was hardly noticeable -
IF you get a suspension related warning/error message on the DIC -
you'll need to install a relay in the trunk to eliminate the messages -
1993 sedan deville
Thanks I was unsure what people were doing when the did away totaly and put in conversion , and eliminated the air ride altogether.
first -
our cars do NOT have air ride -
our cars have coil spring suspension - with oil-filled struts and shocks -
our cars DO have ELC - Electronic Level Control - in the rear -
this system incorporates air bladders in the rear shocks -
designed to lift the BODY - to maintain proper ride height -
when the back seat and/or trunk have an extra load -
eliminating the ELC system is a HUGE mistake -
