Need Your Help/Assistance.......Again
489 Views 2 Replies 3 Participants Last post by  jayoldschool
Greetings,
As of last week, I noticed that my horn has stopped working. I have a 91 Brougham. I checked the 30 amp fuse (that controls the horn) and everything else that feeds of the fuse, power seats, locks, trunk, etc. work. Just wondering what could be the problem? It worked perfectly the last time I remember and I barely had to use it.
Any advice would help!!!
I hope you're not like another post where the problem lay under the horn pad in the steering wheel.
In your case it would be UNDER THE AIR BAG and that gets into really, really serious stuff if that particular wire is broken.
If you don't know what you're doing and that airbag goes off in your kisser, it could mess up your whole day! :bouncy:
It could be the ground on the horns. I had the ground go bad (corrosion) on an old Caprice. Cleaned it up, horns worked fine.
