1 - 8 of 8 Posts
03 escalade
Pretty Please!
Need to know specifics on the stereo plug- having issues with my nav install...
Banned
2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
stock it should be a 32 pin connector thats what all caddys used. what is the problem your having?
03 escalade
Blowing fuse for a/c night-lights and steering wheel night lights (volume, Cruise cntl)
Yes, it's the pin you describe, I'm curious what each position is.
Banned
anyone which a service manual i believe has an image of what each pin is for i cannot recall off the top of my head your gonna have to do some searching i know its posted here somewhere
03 escalade
I've searched, no luck... seen plenty service manual illustrations about the CTS nav unit... I wish we had cadillacfaq.com for devilles, too:crybaby:
Cadillac Technician
none
Radio (w/o U3R,U3S,U3Q)
Connector Part Information
12110115
32-Way F Micro-Pack 100 Series (BLU)
Pin
Wire Color
CircuitNo.
Function
E1
DK GRN
835
Entertainment and Comfort Serial Data
E2-E3
Not Used
E4
RED
1486
FM Composite Signal
E5
YEL
1491
BacklightLamps Control
E6
PPL
1807
Class 2 Serial Data
E7
Bare
814
Drain Wire (w/UE1 and U43)
E8
ORN/BLK
2360
Modem Audio Low Reference (w/UE1 and U43)
E9
TAN/BLK
2388
Modem Audio Return Signal (w/UE1 and U43)
E10
BRN/WHT
2387
Modem Audio Transmit Signal (w/UE1 and U43)
E11
Bare
814
E12
TAN
511
Left Front Low Level Audio Signal (+)
E13
DK GRN
1947
Left Front Low Level Audio Signal (-)
E14
BARE
2011
Drain Wire
E15
BARE
2012
Drain Wire
E16
BLK/WHT
651
Ground
F1
ORN
2240
Battery Positive Voltage
F2
Not Used
F3
WHT
1487
AntennaEnable Signal
F4
DK GRN/WHT
817
Vehicle Speed Signal (w/ UE1 and U43)
F5
BLK
450
Ground
F6
PPL
1807
Class 2 Serial Data
F7-F10
Not Used
F11
BARE
1792
Drain Wire
F12
PPL/WHT
652
Chime Module Bit 2 Signal
F13
DK BLU/WHT
653
Chime Module Bit 1 Signal
F14
LT GRN
1948
Right Front Low Level Audio Signal (-)
F15
LT GRN/BLK
512
Right Front Low Level Audio Signal (+)
F16
TAN
2610
Cellular Microphone Signal (w/UE1 and U43)
Radio C1 (w/U3R,U3S,U3Q)
Connector PartInformation
12110115
32-Way F Micro-Pack Series (DK BLU)
Pin
Wire Color
CircuitNo.
Function
E1
GRY
1698
Antenna Select Supply Voltage (Export)
E2-E3
Not Used
E4
RED
1486
FM Composite Signal
E5
Not Used
E6
PPL
1807
Class 2 Serial Data
E7- E11
Not Used
E12
TAN
511
E13
DK GRN
1947
E14
BARE
2011
Drain Wire
E15
BARE
2012
Drain Wire
E16
BLK
1051
Ground
F1
ORN
3240
BatteryPositive Voltage
F2
DK GRN
817
F3
WHT
1487
Antenna Enable Signal
F4-F5
Not Used
F6
PPL
1807
Class 2 Serial Data
F7-F10
Not Used
F11
BARE
1792
Drain Wire
F12
PPL/WHT
652
F13
DK BLU/WHT
653
F14
LT GRN
1948
F15
LT GRN/BLK
512
F16
Not Used
Radio C2 (w/U3R,U3S,U3Q)
15380274
5-Way F Micro-Pack 100 Series (BLK)
Pin
Wire Color
CircuitNo.
Function
1
TAN
2610
BARE
814
Drain Wire
3-5
Not Used
Radio C2 (w/o U3R,U3S,U3Q)
12064980
9-Way F Micro-Pack 100 Series (BLK)
Pin
Wire Color
CircuitNo.
Function
7
PNK/BLK
2062
Navigation Mono Audio Signal (+)
8
ORN/BLK
2061
Navigation Mono Audio Signal (-)
9-10
Not Used
11
BARE
814
Drain Wire
12
BRN/WHT
2052
Navigation Left Stereo Audio Signal (+)
13
GRY/BLK
2053
Navigation Left Stereo Audio Signal (-)
14
DK GRN/WHT
2054
Navigation Right Stereo Audio Signal (+)
15
PPL/WHT
2055
Navigation Right Stereo Audio Signal (-)
Can you read that okay?
Cadillac Technician
none
PS, to use that please note the headers for the different radio options.
Make sure to match the OLD RPO with your old radio and the NEW rpo for your new radio.
03 escalade
RGR that!
Thanks a ton :)
1 - 8 of 8 Posts
