I'm only posting this because the problem is getting so bad it is changing how I prepare my day and what time I leave my house for activities....
My V, for a while, has had a problem where as soon as I start the car up and try to put it into reverse to get out of my spot, will not, under any circumstances, go into reverse, and will go into a forward gear if i use both hands to push the stick or not into those gears at all either. Today, I couldnt get into reverse at all, allowed the car to roll back into the road, and sat there about 3 minutes trying to get it to go into a drive gear. It wouldnt, so I jammed the stick as hard as I could against first and it somehow connected enough to get my rolling about 5MPH (it was not engaged in the gear though), after I got some speed, did the same to second, and got up to ten. Then I finally got it to go into third with maximum force and a lot of noise.
It was like this for about 5 minutes of driving, then it got slightly better, but still was super-harsh into gears, almost like I needed a new clutch.
After ten minutes of driving, it drove like a million bucks and was shifting smoothly and without resistance, though the clutch pedal was still soft and going to the floor with relative ease.
What is this problem? I don't think it's the actual clutch, because if a clutch goes bad, it doesn't get better as you drive (right?). Same for throwout bearing or those kind of things, they don't get better as you go, they remain in the same state of functionality.
Please please share your mechanical wisdom with me. I just hope its not a clutch. I haven't looked up clutch prices and labor costs for the V cause I'd rather not know haha. What could this be guys? Ask any questions you may have that would help answer the question.
2004 w/ 103K miles, original components.
