2003 CTS
03 CTS
The front flip down coin holder / power outlet. I saw some instructions how to remove it but cannot find the thread where it was posted here. It gave a link on how to take it out, I have some coins that fell behind and they keep sliding around. Any help would be appreciated.
Thanks Dennis :bigroll:
Black the Darkside
denniscts said:
found the post after more searching thanks in advance
Probably found Ody's post?
Re: Ash Tray removal help
The ashtray/climate control panel is held in place by four clips (two on each side), and a hidden bolt that must be removed first. If you open the ashtray you'll see a small hole in the back that leads to a small metric bolt. Remove the bolt, then use a plastic putty knife (not a metal screwdriver!) to pry one edge open, then the other. The whole panel pops out towards you (don't try to simply remove the ashtry). When you put it back, there's no need for the center bolt. The clips are more than enough to hold it in place.
