The car is at the dealer for repairs. 2004 15,000 miles.Both motor mounts, rear diff, center console and clutch sticking to floor. I get a call today that everything is ordered except they said that just a pressure plate was ordered not the entire clutch kit.. They didnt take it apart to look at it,they only test drove it. . I told them that when they had it apart i would come up and look at the clutch and flywheel to see if theres any damage. I gave them the tsb write up so if there is damage they should replace the entire setup...right???
A few Questions:
Are the clutch, flywheel and pressure plate three seperate parts?
What should i look for on the flywheel and clutch to see if they are bad?
If i decide to go aftermarket clutch and or flywheel, is the stock pressure plate good enough?
What clutch and flywheel are good upgrades? I have a maggie and cam waiting to go on! Spec, UUC, textrillia?????
Thanks for advice!
A few Questions:
Thanks for advice!
