2010 cts 3.6
I have a 2010 CTS with Nav.When I shut off the ignition and open the door the NAV screen shut off and lowered. Now it stays up and doesn't shut off when I exit the car... What should I do? I Don't want it to kill the battery. Its sitting in the garage with screen up.
2019 CTS
There was a problem similar to this discussed some time ago. It turned out to be a bad driver's door interlock switch. Try leaving your radio playing and turn off the key and open the drivers door. If the radio continues to play then its the drivers door. If the radio goes off as it should, then you are looking a a different problem.
