1 - 16 of 16 Posts
05 Stealth Gray V
Ok heres the deal. I know we have talked about this time and time again. But I have not got it resolved yet and it is starting to piss me off :want:. If I turn my A/C on when I start my car the oil temp is fine (well around 230-250) If im driving with the windows down it is about the same. And somethime it goes up for a bit till I start driving again. The problem is this. If im driving for more then 15 minutes and decide to put the air on the temp goes through the roof! I mean 300-320 can you say hot! So whats the deal. Yes im in south florida where its hot and humid but when its sunny somedays I like the heat then it becomes to much. What do I do? and has anyone else had this problem?
Gene
'09 V BR 4dr 6spd,'05 C6R 1400+HP, '05 V BEST EVA!!
I had same issue, spent over 40 hours on it, replaced everything, nothing worked, sensor is now unwired. Ticked me off, but I was convinced everything that could be looked at was, no stone was unturned. Take your car to the dealer, hopefully they can find the gremlin.
05 Stealth Gray V
I did and crickets! They had nothing to say. I am kinda friendly with my service advisor (we talk a lot about cars. He has a lighting and a r1 bike) and he said that it is puzzling them also. The dealership is very familar with the V also. I don't know what else to do. I really can't put oil cooler on right now. So I guess I will have to wait and see. I will not drive it as much in the summer I guess.
Darren did you get my PM earlier today?
Gents -
Are you sure this isn't the miscalibrated gauge issue? There was a TSB early on. Dealer needs to recalibrate the gauge cluster...let me see if I can find it.
WW
05 Stealth Gray V
Thank Bill! It is driving me crazy. I hate not being able to drive my car. I bought it because here in FL we can drive our sports cars all year long. (damn miles)
From the .faq -
PI01886A PI Oil Temperature Running High - kw 5.7 hot light LS6 proactive May 6, 2004
See you in the funny papers
04 CTS-V, 05 STS, 07 SRX- All sold :(
Had the same problem, Gene. Reflash fixed me right up.
Oil temps now hover right at 220 when warmed up.
05 Stealth Gray V
Discussion Starter · #10 ·
cool guys thanks. I will talk with scott (my service guy) today and have him reflash it.
Thanks for the info, I hope it's the cure.
My V did the same thing about a year ago. Had TSB done and no problems since. Often the dealers are not up to speed on the bulletins so I usually print them off and take 'em with me.
Does anyone thing you could have an oil temp of 320 and not have cause your coolant temp to increase? Seems like it would...
05 Stealth Gray V
Discussion Starter · #13 ·
well I just talked to my service advisor and he made me a appt for monday. He looked up the TSB while I was on the phone and said that it was for the 04 not the 05. But I am going to do just that, Print out the stuff and bring it to him.
I just did a quick search for all warranty claims relating to high oil temp for 04 through 06 models. The issue is only on the 04's. Not sure what to say about your problem...sorry.
Ok. Got it. There is a IPC out for 2005MY
The document # is 1972141
Subject: Engine Oil Temperature Reads High Or False Warning Message - keywords DIC display gauge IPC #PIC4508 - (05/15/2007)
Models: 2005 Cadillac CTS-V
Condition/Concern:
Some customers may comment the engine oil temperature rises very quickly and remains high when they are not driving on long hills or performing aggressive maneuvers. In some cases the Oil Temperature Warning Message is displayed.
Hope this helps.
Premium Member
2005 CTS-V
Bingo. If you've got acceptable coolant temperature and good oil pressure its almost a cinch that a high oil temperature is a false reading of some sort.
1 - 16 of 16 Posts
