I think i am in the right forum, please don't get mad if im not.
Alright, so i have a 77 sedan deville with a built up(hot cam, high compression heads & pistons, forged rods, aluminum intake, 870 cfm carb ect...) caddy 500 motor. I currently have the stock th400 trans in just so i can run it around and break in the motor, soon ill swap it out with a tremec TKO600 5-speed trans. So the big question is what rear(brand and ratio) should i use that is also a posi? i would like to keep the housing and just replace the pumpkin guts if possible. Any and all suggestions would be helpful.
95 FWB 81SDV 96 FWB 94 Fleetwood
You will be better off building another th400 with all the best parts.. standards have a hard time standing up to the torque of the 500...For a rear , I think a 3.08 is a good ratio for the 500...a 77-79 limo has a 3.08 gear with 33 spline axles... Or a 96 or earlier chev cop car has a rear that will bolt in...not sure of there gear ratio...
K
Guest
Depends on what you’re looking for. You can do a search and find numerous tire size gear ratio calculators for drag racing.
94 ETC,97 STS
500's have prodigious torque and don't have to run high rpm's so the 3.08's would be a good choice.
I had a couple of 5.0 Mustangs. They ran 2.76's with the 5spd.
