· 1995 Deville 4.9
1995 Deville 4.9
1995 Cadillac Deville 4.9
After removing the Air Intake Manifold to replace the thermostat I noticed my Throttle Body Mounting Gasket was practically ceramic and broken in 3 pieces.
I tried to find the Mounting Gasket but only found the Throttle Body Gasket. When I removed my Air Intake Manifold there was no gasket to begin with.
I can find Throttle Body Mounting Gaskets, but only for the '95 Seville.
So here's the question: which gaskets do my engine require? Do I only need the Throttle Body Gasket? Or should I get the Mounting Gaskets for a Seville for a total of 3?
· 2004 Deville base
'05 SRX N*/AWD, Vetts/Birds/Trucks
If you are talking about the 'round' gasket on top of the throttle body, for the spacer/air intake lid/cover, it is pretty common, and widely available. Very close to the same on carburetors.
I just make them in a pinch, cereal box/single layer cardboard. Or 1/8" thick heat trace insulating wrap works the best, but you do have to cut it and mess around a bit more
The '95 Seville is the 4.6 N*, the intakes have nothing in common.
'92-'94 on a "4.9" in a Seville...I think. still learning.
· 1995 Deville 4.9
1995 Deville 4.9
I indeed mean the round spacer gasket, but when trying to find one for a '95 Deville the only exact fit results are for the Throttle Body Gasket. All results for the spacers are made for the Seville, and trying to find one for a Deville returns zero results.
06 SRX base (gold)
Orielly's has the gasket you need. Its a Felpro, ask them to look for breather gasket. If your still having trouble, I'll look up the number for you. Its a paper gasket, and very well made. Good Luck!!
