91 fleetwood 61 special
I have a 91 Fleetwood 63 special, runs and idles poor, after warmed up it runs a lot better. I pulled the codes PO101 through PO109 which the scan tool said were for MAF and manifold pressure. Where should a person start?
I put in a new MAP sensor tonight, didnt seam to change anything. starts up and runs fine, excels fine but when you let off the gas pedel the car misses and runs poor for a bit then clears up.
Might want to check for vacuum leaks before replacing the MAF sensor since I think they are a bit pricey.
