I have had a 2007 DTS since 2008 been a good car no problems for the most part however I started to replace suspension parts and for the last 4000 miles after I decided I needed to fix a strut mount issues beginning in Fall and all winter I can not figure out were this steering wheel shake is coming from.
I put in both sides new
1) Outer Tie Rods
2) Timken Wheel Bearings
3) Half Shafts
4) Sway Bar Bushings
5) Front Rotors
6) Detroit Axle Heavy Duty Strut Assemblies (Strut/Bearing/Springs)
The wheel shake is intermittent and can happen as slow is 30 mph and just gets tighter with speed or acceleration. I have had passenger complain of vibration from the passenger side and I had herd a faint sound coming from passenger that was in sync with wheel shake but not a classic half shaft click. When I took the half shaft out on the passenger side I noticed the transmission output shaft had allot of up down play but the seal was not leaking. So the new half shaft went in hoping just maybe it would fix.
I had the front end shop align the front and rear end twice (Tires swapped front to back second alignment), balance the tires twice (2nd Time Road Force Balance front) and they could not find anything wrong with the suspension (Its all new except Steering Rack). The Tie rods are tight enough to hold position when out of the knuckle but there is slight movement when rocked side to side with tire on.
I don't know were to go on this one. The Rack and Passenger Side Output shaft (Which apparently may be serviceable on vehicle per service manual) are still suspect.
Any ideals?
1) Outer Tie Rods
3) Half Shafts
5) Front Rotors
Any ideals?
