Hi,
I have a 1996 SLS that the key fobs don't work. I have replaced the batteries and cleaned the switch contacts. I suspect it either needs reprogrammmed or replaced. Any suggestions??? What is the procedure to program???
Thanks,
woodysls
96 SLS
Open and look closely at small square sitting on top of circuit board. I had similiar problem where remotes did not work. Had a friend look at and fix. Small crack in sodier which prevented from working correctly. I did not have to re-program -just replaced battery. Had to see - so look really close.
