1 - 9 of 9 Posts
2005 CTS-V, 1994 Infiniti Q45
Ignition ON.
Ground black single wire connector located at trunk pull down unit.
Wait for door locks to lock and unlock [a few seconds]
Press the UNLOCK button on the first transmitter twice. Pause for one second between presses.
Wait for door locks to lock and unlock. [a couple of seconds]
Press the UNLOCK button on the second transmitter twice. Pause for one second between presses.
Wait for door locks to lock and unlock. About two seconds.
Remove ground from black connector.
After procedure, check to see if both transmitters operate the door locks. Repeat programming procedure or replace transmitters as necessary.
53 Eldo, 54 CDV, 74 FWB 96 FWB (sold),1998 STS(sold), 03 ESV
Sounds like a plan!
Let me know if it worked!!!!
1996 El Dorado
on my 96 el do i just held down the unlock and locked buttons on my fob til the locks locked and the lights flashed....
97 Seville, Sisters 93 Deville
what you need to do is take the black cover were the pull down motor is and their should be a wire their thats lose and that the one you ground... then from what it seems follow the instructions... i only have been able to do one doing the same procedure but never knew how to do the second until reading this thread.. hope it helped.
1 - 9 of 9 Posts
