88 Sedan Deville, 89 Eldorado, 11 SRX, 18 CT6
what specs are you looking for?
if it's a 4.5Lv8 here is prolly what your looking for...
Engine: overhead valve: aluminum block with cast iron liners. 273 CID (4.5 liters) bore and stroke: 3.62x3.31 inches. compression ratio 9.0:1 net brake HP 155 @4000 RPM. taxable hp 42.00 net torque 240 @2800 rpm. five main bearings roller hydrolic valve lifters. /digital fuel injection VINCODE 5. built by cadillac.
wheelbase: 110.8 inches. length 196.5 inches. height 55.0 inches. width 71.7 inches. front tread 60.3 rear tread 59.8 inches
standard tires : P205/75R14
transmission: THM 440-T4 four speed automatic includes overdrive and viscous converter clutch.
steering- power assist rack and pinion.
independant machhersun strut with coil springs strut type shock absorbers.
rear - fully independent with coil springs. A.L.C. with strut type superlift air struts.
power disk / rear drum brakes (std)
18 gallon fuel tank.
anything else on that 88 you need, part numbers, how to get the computer codes out of the climate control panel, etc, lemme know. ive got that same one.
mines darker metallic blue, unsure of the name of the color, with royal blue leather interior> i think thats the name... sweet ride, whats specs, price, etc. any options it have that arent base model> stereo, etc. where from
