2000 Deville
My 2000 Deville has been idling very erratic. Code 0101 current. Replaced MAF and MAP Sensors. Checked for vacuum leak. Sprayed TB cleaner on side of Throttle Body next to motor (Plenum??) and engine races. Seems like gasket is leaking . How difficult is this to replace? Any advice is appreciated.
Are you sure it is not the "plenum" (rubber coupler) between the TB and manifold? That seems to be becoming somewhat common lately.
2000 Deville
That is possible (Is it about 1/2 " to 1"wide and connects the TB to the large black metal part which apparently distributes the fuel to the cylinders). Looks like there is a large hose clamp right up against the TB. If so, is it simply a matter of loosing that clamp and replacing the rubber piece? Hopefully don't have to take the TB off.
By the way you were right about a month ago relative to replacing front wheel bearing. Mine made a growling sound - took about an hr and 1/2 to replace. Thanks again you are always helpful
Thanks.
Do a search for "plenum". It has been recently discussed. I am not sure , but I think I remember someone (maybe Ewill3rd) saying that the manifold (or TB) needs to be removed.
