1 - 14 of 14 Posts
06 STS-V, 94 Fleetwood TS
Here are the instructions for getting into the diagnostic mode of the STS and STS-V navigation/audio/video system.
Use at your own risk...
Press the "MENU" button while in the navigation mode.
Next to the header, press and hold in the center of the screen as shown for about 5-7 seconds.
When the keypad appears, enter "9448" and then press "OK".
You will then be presented with 2 pages of options.
This should answer any questions that there is a gyro on board because on this screen you can read the signals from it.
How comfortable does it make you feel about our government when 12 satellites can see you inside your garage?
The hard switch test is pretty cool.
The color adjustment screen.
There are more as well. I would suggest being especially careful with "Ship Mode" and the touch screen calibration.
No, I did not find the code for unlocking DVD view while out of park or the one to allow my passenger to imput stuff while driving.
06 STS-1SG-ACC/HUD-Volant CAI-Corsa Exh-Mesh Grill-ClearBra
A little knowledge can be a very dangerous thing!
Thanks ssstealth...:D
10 CTS-V, 13 ESCALADE, 06 C6, YAM R1
GREAT INFO !
do you know if you are able to adjust any of the gyro settings, like the sensitivity?
2008 STS V6 DI, 2014 XTS Premium AWD V-Sport
Does anyone know the NAV Diagnostic PIN for a 2008 STS.
I get to the keypad screen but when I enter PIN 9448 I get kicked back to the first menu screen.
Thanks in advance.
Pete
I had no clue that the 9448 would not work for newer years but it makes sense I guess. The DeVille used 1791 forever so that may be worth a try. As I recall, I found the 9448 code on a Corvette or SRX forum. There were actually several codes that worked but some locked you into diag mode until the car was restarted.
Also note before you just start plugging away at 0001 that someone had got into the code and found that the system allowed for up to a six digit pin. :eek:
11v,2 09 v's,2 05 v's,5 GTM supercars,viper,volt,2012 karma
660 popped up a menu with alot more things in it on mine.
2013 OBM CTS-V Coupe
P.S. DO NOT do this while driving. It locks up your unit until you shut off the car. What ever volume you have it on will lock up and you can do anything.
Don't ask how I know:bigroll:
2006 STS 1SF N* RWD NAV F55
Anyone know if you can get the Radio ID, (NOT XM) from the diagnostic screen ?
Vice: removing the radio and reading it OFF the back of unit.
i.e. A number like 10377613 or 15256169 or 15233578 or 15793847 ?:thumbsup::cool::cool:
1 - 14 of 14 Posts
