If you have followed any of my threads, you know well I don't shotgun any troubleshooting. Component level electronic parts replacement is my job, even to TS-16949 (the new QS-9000) FAI (Failure Analysis Investigation). I want to see only one bad part on my bench when I am done. Which is why I get soooooo ticked off at these garden variety mechanics working for shops and dealerships that send you a $1000 bill for 3 bad parts. When only 1 is bad, but they use your money to troubleshoot what they don't understand. It is my soap box..... Not saying all mechanics are bad, but too many for me, so I do my own work because of it. I can't afford to throw $$ into a garbage can just for the sake of a clueless mechanic. If you put a part on that doesn't fix it, take it back off. PERIOD. You have NO right to charge the customer for it and lie about it being bad when that part didn't fix the problem. How many BILLIONS of $$ each year are wasted by customers to take their cars to shops and get multple parts replaced for 1 bad part, when they replaced lots of good ones because they didn't troubleshoot properly or take the time to do it right and pull the parts back off that weren't bad. RARELY, I MEAN RARELY do multiple parts ever go bad. Like the planets probably line up more often. I have seen it 2x on my 76 Olds, and never did get an answer, but I was able to prove it did it, but it baffled me (fuel pump went out, took out ignition module, years later, float died in carb, took out ignition module... I suspect early design and electrical surge from trying to crank it or jump it). (Getting off soap box, you don't want me going on and on...)
1. Yes, pulling #7 injector connector yields no difference in idle speed or power, it misses just the same. I have been leaning towards #7 injector for a while, but I really want to do the officially power balance test, can it be done with a 96 N* with the climate control display?
2. Swapping coil around data I should have today, but #7 is missing, #6 is not (the partner waste spark cyl). I swapped the positions of #6 and #7, no change. I didn't expect any, but simple to do.
3. If I am having a bad plug (they are new, but I didn't put them in) or wire, I would expect 2 cyls to miss, not 1 due to the nature of waste spark.
4. Looking at the BLM's, or LTFT if you call it that, (I am old school, BLM is what I use) they are split, and assuming that GM wouldn't ship them split that much, there must be a reason. GM typicallys shoots for lean over rich in the BLM range (you run the injector constant a bit over what the injector is and it runs towards the edge of lean, or positive LTFT/BLM). Being #6 and #7 are on different banks, it shows me more that it isn't an ignition problem. For giggles and grins, I moved the #6/#7 coil to the next one over and wired accordingly and still have miss, but I haven't been near the car to read the codes.
5. Reseting fuel trims won't accomplish anything, it will learn it back in seconds, or learn it right.
6. Questions I have:
1. Does this have dual cats? If one was plugged, I would get rich O2's. I can see that, but I cannot accept it would miss on #7 only. I keep fighting the owner of the car to go replace them, you can't just keep throwing money at a problem to make it go away unless you have unlimited resources.
2. I personally have never seen a leaking injector, but looking how this car was treated, I wouldn't say no, it is rough. GM did the fuel rail recently, and didn't seem to indicate anything at all, so the mech either didn't volunteer any info if he saw something wrong or there was nothing to see. Probably a R&R job and get it out the door, it took them about 1hr tops.
3. Which bank is which? Front/Back = Bank1/Bank2? I agree, time to pull the plugs back out and look. What is preferred gap? He said he set it, but again, I haven't looked at them personally. I worry when I don't do the work that is was don't right.
Fuel trims DO get balanced once you punch it (PE mode), but it doesn't take long once you get out of PE mode that they go back to -11%/3%. 11% is quite a bit in my book, I don't let my LT1 get that far out ever.
The injector ohms good, as do the wires and coils.
