1 - 20 of 26 Posts
1995 Eldorado/Slate (R.I.P.) 1997 STS, 2002 Eldorado ETC
Okay, here goes. My 95 Eldorado has a klanking sound coming from (possibly) the bottom end. I had a complete bottom end rebuild at 150K. It "klanks" along with the starter, and at idle speed (around 750 rpms). The engine sounds perfect at or above 900 rpms). Newer transmission, flexplate and torque converter. ( I checked them all, no play) My question.. what the hell is it? It sounds like someone banging two oil cans together (for those who remember oil cans). I thought the bottom end of the N* was bulletproof.
The only code I'm pulling is a P132 -knock sensor circutry. I don't think a bad knock sensor would even cause this noise.
Anyhow, any ideas? Would a bad belt tensioner make this noise? Belt driven accessories?
As always.. thanks for the input ahead of time.
Hey Ranger.. sorry, forgot to say that I replaced the starter too. That would be too easy, now wouldn't it? ;)
edit: Now, you have an idea of the "klanking" sound I'm talking about though. It would sound like the starter pinion stuck out and banging off the flex plate.
98 deville D'Elegance 86 Fiero 2m4 / 86 Fiero GT W/SBC
possibly a hairline crack in flywheel? Borrowed a truck that had the noise you are describing last year. The flywheel had no play but we dropped the tranny anyway, and low and behold it had a crack near the mounting bolts. Replaced it and the sound was gone.
It only did it at an idle or certain unloading conditions, never during acceleration
Edit: Hopefully it IS your starter pinion.
The flexplate was changed last summer. I'm wondering if anyone has shimmed their starter. I've used shims on other GM vehicle's starters, but they were the exterior type.
· Super Moderator
2010 DTS
Never heard of one needing to be shimmed.
Try this. Take it for a ride and make a hard right turn. If you hear that clanking, then I'd put money on the pinion returns spring. Centrifugal force would be throwing the pinion into the spinning flywheel ring gear. A hard left would slide it back away from the flywheel.
Discussion Starter · #9 ·
It was a cheap aftermarket starter... 70 bucks on ebay. The sound didn't go away in the first start though. I'm wondering if those goofballs put my flexplate in wrong. I went for more than a year without this noise. I was really listening last night, and the starter might just be the problem.
My money is on a cracked flexplate where it bolts to the crankshaft. Sometimes you can see a rust streak from the bolt on the flexplate face. The crack flexes and rust forms on the crack and streaks down from the bolt hole. The flex plate is a very tight fit on the crankshaft end. If not fully seated when replaced, it would flex too much and crack. Why was the flex plate replaced in the first place?
Discussion Starter · #13 ·
The flexplate was switched out, after 214,000 miles. It centered out, so I don't think it's the problem. One question for all. How many portals are there to check the crank/flexplate. I'm thinking a wrench is in there. seriously.. :/
2001 DeVille
Have you checked the Harmonic Damper? It's common, esp. at your mileage. Pull the LH front wheel and liner to expose it and look for defunct elastomer between the hub and pulley. If you can just look down at it and see anything or it wobbles you've found it already.
Vernon
· Administrator
Vernon
RF wheel - the balancer is on the "passenger side" - the front of the engine.
"Clanking" in time with the starter sure sounds flexplate/torque converter related.
You might be able to get a peek in the bottom flexplate cover - under the transmission. Can't see much through the starter opening - with the intake manifold removed.
I didn't even think about the torque converter, been there done that also, almost the same sound as the broken flexplate I had. It was on a grand caravan with a 3.3
Sounds alot like a bent rod contacting the block or something, except it was not constant. Again it was at idle and certain unloading conditions never during acceleration, until they got too loose then it was any rpm and free spinning but not accelerating.
At least that you can check when you have starter out (1 bolt at a time).
My caravan happened about a year after garage swapped a motor for me. They never put loctite on the threads. All the bolts were loose, but I didn't loose any.
This flex plate is held to the crank flange as well as the outer edge of the torque converter. You can access the t/ converter bolts, but not the crank flange without at least, partially removing the transmission! as I mentioned earlier, if there is a crack at the crank flange it will in most cases, leave a rust stain down from it.
Discussion Starter · #20 ·
Vernon
You know what? You're probably on to something. I'm going to check tomorrow. I was looking at the wrong side of the motor and my symptoms sound like something up that alley. Thanks!
I had a brand new flexplate put in about a year ago.
When I said the flexplate "centered out".. was something like this
http://jaguar.professional.org/snaps/ford/flexplate_out_2.jpg
1 - 20 of 26 Posts
