98 seville sts
I am excited about my 98 sts. It had a couple of minor problems like it needed a water pump. we did that but the on board computer dash still says check coolant level. Is this a computer re set issue and do I just plung my computer in like I am geting codes, then erase to make the message go away. Thanks
Hyundai Elantra
Welcome to the forum! :wavehi:
Two possibilities... One is the sensor in the bottom of the surge tank is bad and you will have to replace the tank. If you have added the specified level of coolant and the car continues to show the message as soon as you start it this is the most likely cause (with no obvious leaks on the ground of course).
The other possibility is the car is actually using coolant, most likely due to headbolt/headgasket failure. Low coolant warnings are usually the early signs of this followed by overheating. Do a search for "headgasket" in the Seville and Northstar mechanical forums for all the info you ever wanted.
I am redirecting this thread to the appropriate forum for you. Welcome!
