I fixed my headlight problem. it was definatly the ballast.
here is what I did, I hope it helps someone out.
I ordered a "Oem replacement Slim Ballast for d1s HID" from ebay. it was 59 bucks plus shipping.
I removed the bumper cover, and headlight to find the ballast with water dammage. I had never done this before and learned that the ballast actually is the bottome plate to the headlight housing so you cant just remove it and use another one. I also saw that the ballast is not water tight from INSIDE the headlight housing (wich is how mine fried).
there is a gap in the corners of the ballast, so I poped it open to see whats inside.
to keep this short, I came up with a plan. I filed the inside of the rectangle a little and the new ballast would fit tight in the hole. so I tore the electronics off the back plate of the old ballast, ground the stand-offs smooth, and bolted the new ballast to it. used a good sealer around the bolt holes.
Just a little bit of filing, seriously like .5mm per side.
Ground inside of back plate smooth
Soldered new Power Wires to the existing power wires from the old ballast (mine was a 12 pin, but only 2 wires were being used, I used a volt meter to find + and -
New Ballast mounted in place of old electronics.
All together, putting screws back in to headlight, using the old rubber gasket from old ballast.
I used some good adhesive bonding sealer around the inside of the bolts and then after, on the outside. I also ran a little bead around the outside in case the rubber gasket didnt seal right, but I belive it was fine on its own.
here is the end result (Bad pic because of Droid Camera over exposes as night)
I also installed some Blue LED 194 lights too.
I hope this helps anyone out. the Whole job cost less then 100 bucks with the Ballast, Shipping, sealer, bolts, etc.
-John
Phoenix, AZ
-John
Phoenix, AZ
