1992 Cadillac Deville Touring Sedan
The Fix-It List: A Journey to fix Eve
My car is a 1992 Cadillac Deville Touring Sedan with a 4.9L V8 engine. It's beautiful, comfortable, and aesthetically pleasing. She drives very nice for the neglect that it had experienced. I named her Eve, since my family is religious and it's a Deville, I thought it would be catchy, but now it sounds more attention-seeking lol. Anyways this is my first project car and I wanted to go all in so that I can provide a real experience of fixing a cool 30-year-old car on a budget.
This is mostly for my own memory. Help is always appreciated but never expected.
To begin, we have already got some new tires, and I learned at that shop that my rear tire cambers -3 degrees, and the front is bent in a bit. But before I get an alignment, I need new struts all around. Shit is getting expensive.
Put in Marvel's Mystery Oil to quiet a lifter tick, and so far, it's not doing that much; need to drive more miles with it. ATF was thrown in too so I can save my Marvel's Mystery Oil.
Next week I need to go and get a tune up; basically, need fuel filter and spark set/distributor.
I am missing some underhood relays from the car. Can't tell what they are supposed to be, but I can bet its all three cooling fan relays.
Current Issues (prioritized):
  • Lifter noise from the engine
  • Not sparking too well and engine is outdated (diagnosed; tune up will fix it)
  • Wheels unaligned, cambering, and could cause tire damage
  • Leaks: puddle on the valve train. Obvious gasket issue. Leak in the back end of engine, but isn't worth the lift
    • oil had never touched the ground, so this isn't too too bad. The oil near the valvetrain is sus though
  • Electrical:
    • Climate Control only turns on sometimes. Looking at wires soon but it could be the panel or BCM.
    • Cruise Control is obsolete. Not switching whatsoever. Fuse, wire, or connector issue? Switch?
    • ABS brake lock and traction will flicker on and off sometimes. Wire issue for sure.
    • A/C service light on; may indicate lack of refrigerant or that the relays are out.
    • Radio disconnected; previous owner wanted to get subs. Little did they know these cars are 50% wire.
Here is what parts Eve, my little devil, needs:
  • TUNE UP: Fuel filter, distributor cap + rotor, spark plugs + wires. quoted at about $400
  • Struts all around and alignment. maybe $500? got a rough joint too
  • Valve gasket $20
  • Lifter (?)
    • Still gotta figure out if Marvel's or ATF can clean it up more,
  • BCM? $130
    • Still looking into this one, but I'm hearing every 90s Deville owner should keep a spare.
  • wire connectors
    • wires need to be connected again and we need to investigate more
That is my comprehensive list for my ADD brain. All this figured out in one week. Bought the car ten days ago and she's made me give nothing but attention to her. Hope it's all worth it!
Discussion Starter · #2 ·
  • Electrical:
  • Valve gasket $20
  • Lifter (?)
  • BCM? $130
  • wire connectors
I got codes E52 (disconnected battery recently); F30 (I think it is freon i need); F48 (x2, its about the Electronic Climate Control + BCM being disconnected).
· Master of the Dark Art of Diagnostics
  • Electrical:
  • Valve gasket $20
  • Lifter (?)
  • BCM? $130
  • wire connectors
I just found a HELL-OF-A-DEAL for you -
REAR STRUTS -
MONROE 71798 - $62 - for a PAIR - including shipping - YES - these are the air-assist struts!
these are a special close-out deal from ROCKAUTO.COM -
HURRY - because they only have 2 left -
FRONT STRUTS -
I recommend the MONROE 171822 QuickStrut -
these are complete - fully assembles struts with all new parts -
new mounts - bearings - springs - etc -
$92 each - plus shipping - around $203 for the pair - including shipping -
TOTAL for all 4 struts $266 - including shipping -
· Super Moderator
  • BCM? $130
Welcome to Cadillac Forums, Travis-
You picked a great car to revive.
Listen to bass regarding the suspension components and act fast to secure the deals he's found for you.
I used the Monroe rear units and they provide a comfortable ride.
I replaced the BCM in my '89 CDV ~6 years ago with a used unit found on eBay that set me back a whopping $30.
No issues whatsoever.
Reactions: travisjakob
absolutely beautiful ride you got there. I honestly can't wait to finish repairs but I am having some fun doing it. Def gonna get those struts too! thank you everyone
