Have some issues with my car, First, there was a message says "service stability systems", when that came the gear shift would not operate, the button on the level was locked after the message come, then i discovered that if i turn off the car, started it again and hurry to move it out of park it worked as normal, then i also have another problem every time it is winter and started to be cold, the alarm starts in the middle of the night, last winter i just removed the fuze to the Horn, and it worked, but now i have seen something here earlier that try to disconnect the battery could might help with the service message about the stability system, so i did try that disconnected the + pole, and waited 5 - 15 min and put it back in, then my serious problems started, the alarm went crazy, the fuze for the horn was out but it was beeping from somewhere in the trunk, and whatever i did nothing helped, then i did try to reset the alarm system, as i could see on google search i should live the car with ignition on, and remove the ECM fuze for 10 min, so ok i did that, then the alarm continued, all the light went on and the car locked all doors, (and i could hear that i forgot to turn off the heat so the fan went on full inside) well after 5 min the alarm stopped beeping, and after 10 min i put the fuze back in, and the lights went off, but the doors where still locked so i had to pick up my spare keys to unlock and get in the car, ater that my car i more or less dead (except for the alarm whom starts beeping from the trunk every time i connect the battery) the fuze for the horn is also back in place but the alarm does not give any sound from the Horn any more for some reason, well if i turn on the ignition the lights on the dash comes on for a moment, the infotainment display say nothing, and if i try to start all light and all just dies (except for that darn alarm) i did try to measure my battery but first all the problem with the alarm, then 10 min + with the fan working on high speed, and all lights on and ignition on i guess it has drained it a lot, but it still reads 11,20 on the multimeter, and i would believe that is enough to start up, any one have any idea what i can do?
