2016 CTS-V Crystal White, CF,AM Wheels
Received my upgrade parts from Jesse. I wanted to get a baseline so found a shop open today and called him up last minute for some baseline dyno runs.
First run was 477.96hp 462 tq
Outside temp was about 74degree. SAE smoothing was 2 on a Dynojet
Waited about 10 min in between runs. Held pretty consistent
Car in 4th gear(Auto) for pull along with stabletrack fully off. Hit traction control twice then hold for 20 secs or so.
Very inpressed with the numbers. I know they are just numbers and a starting baseline. I have the Jesse's lower pulley, Ht exchanger, Airaid CAI, and his SCT handheld (waiting on tunes from Jesse) to be installed in the next week or so.
Then I will head back to see the difference on the dyno.
I scan the sheet in twice. For some reason my scanner will not pick up the whole page.
Dennis
'09 CTS-V, 3K miles & '87 Turbo Buick, 29K miles
A6 tranny in your car, correct?
Jesse's drop in tune probably won't be quite as close as your tuner can bring it in on a dyno. Might want to consider having your tuner install his tune in the handheld. Might want to check with Jesse on that also. Thanks for posting up the dyno sheet. If that's an auto, those are very good #'s.
Discussion Starter · #4 ·
Hi Gary,
Yes its a auto. I already paid for the handheld from Jesse. Hopefully it will net great results.
Had 2009 V, Red/Blk 2016 Now
Yes, a nice baseline. I have the same things too, but aren't the tunes already loaded in the hand held?
Discussion Starter · #6 ·
No tunes in hand held. Jesse said to read my factory tune -> email it and he will adjust and send back.
Chances are that Jesse's tune will not bring the tune in as close as a local tuner can, providing that you have a local tuner that's good. There again, the difference may not be worth having your car tuned by a local tuner. Just a thought.
