1972 Eldorado, 2002 DTS, 507 Caddy Powered Oldsmobile 442
Hello all I just want to say hello, and tell a little about my project build. I started with a really good 500 block and crank, which I took to the machine shop to be hot tanked and bore .030 over so it should be 507 cid now. I also had the machine shop assemble the block and balance it as well. Here is a list of parts the best I can remember:
- Keith Black Hypereutectic Pistons - KB 382,
- 76 cc combustion chamber heads,
- Edelbrock Performer manifold,
- MTS shaft rocker assembly,
- Holley 870 CFM Street Avenger Carburetor,
- Lunati #34603 Bracket Race Camshaft,
- advertised Duration IN/EX: 285/316
- Duration @.050 IN/EX: 230/241
- Gross Valve Lift IN/EX: .515"/.520"
- Lobe Sep Angle / Intake Ctr Line: 110/108
- Valve Lash IN/EX: Hyd/Hyd
- RPM Range: 2500-6500
- Holley 110 GPH "Blue" Electric Fuel Pump With Regulator,
- Sanderson Headers
