Well, I haven’t been on this site for quite a while. Other than to drop in as an observer, that is. But now I have to come back with some questions on my 2001 Deville with 176,269 miles on it. It started overheating. I have had to add quite a bit of coolant into it, so I began to dread the infamous head gasket failure. Curiously, the car still ran well, but several times it got so hot that the red indicator came on and I had to stop the car to let it cool down and put water or anti-freeze into the reservoir. I did replace the cap for the reservoir.
The car has had a P0420 code for a couple of years, and I just erase it. Sometimes the trouble light stayed off for weeks. But the car started overheating. I looked all over for leaks, and didn’t find any. So I got the kit from O’Reilly’s to do the block test. The videos on YouTube seem to show that the temperature stays OK if the car is just idling. They say to let the car warm up and then do the test. For me, however, the car started to warm up and then get to the point where it needed pressure to stop from boiling. When I used the kit and the fluid, I didn’t have to use the bulb to pull gasses into the test chamber, it did it by itself. And I let it bubble as it wanted for several minutes. The fluid stayed blue. So my first question is did the block test indicate properly, or am I supposed to do it sooner somehow so the pressure in the system doesn’t force gasses into the test chamber?
Besides the P0420 code, the new cap, and the block test, I did a few more things. I know that there might be a blockage in the hose that goes into the top of the reservoir. Apparently, this is supposed to allow bubbles inside the engine to vent when you change the coolant. I checked this hose, and it didn’t flow at all. The video I saw showed that it was always flowing, and in fact the flow would increase when the car was revved up. I got nothing. So I pulled off the “hollow bolt” and looked in it, and it wasn’t clogged and I put it back on. I blew into the hose at that end, and coolant came out of the fitting. Then, I re-attached the hose, went to the other end at the reservoir, and blew into that. I heard a bubbling way down inside the engine. My next question is: does that sound like the purge system is OK? Although the video on YouTube shows coolant flowing, I don’t know if it always does this all the time, or does the thermostat have to be open? I stopped for the day at this point.
So, to recap ?:
There is the P0420 code and perhaps a clogged catalytic converter.
There is the possibility that I did the block test wrong.
There is the possibility that the purge/hose thingy isn’t working right.
And finally, there is the oil question:
I had just put brand new synthetic oil in the car. With the overheating and so on, the computer now says that I should change the engine oil. But it is synthetic. I have to say that the car never got so hot that it had to use the emergency system where it shuts down or runs in limp home mode. I’m thinking that I should just re-set the counter and maybe change the oil again in 3000 miles or so. The oil doesn’t seem to be discolored, but maybe.
The car is still jacked up. I haven’t stopped the job yet, but I’m hoping that I can get a few checkpoints set up before I try to drive it again.
So: Any ideas? Questions? Snide remarks?
So, to recap ?:
