1 - 11 of 11 Posts
not anymore 2007 Lexus ES350
I got into my car thismorning and all of a sudden there was a MSG in the MSG Center it said speed limmited to 90 MPH
i was curious so went out on my uncles back road by his house and when i got to 90mph msg came up fuel cutt off and it had started to shut down once i got to 90
what is going on
2000 STS
it is your suspension what happens is you car cannot read the suspension and the computer does not know what to do so it limits you to 90. I have after market suspension and as soon as I added the suspension I was limited to 90 as well.
Is either suspension level/solenoid valve, air or wheel speed sensor, no matter what it has to be a code.
nope no codes i checked them and there are no codes comming up except for one that has to do with the fualty gas guage that has been comming up since i have had the car the past few months
Discussion Starter #8
and the MSG does not come up anymore it just came up that one time and then did not come back and there is nothing store in the history or current
My 99 would occassionally pop that warning after I used the aftermarket remote starter. Never found out why and it has not done it recently. Its possible that you had a code that clears in a small number of ignition cycles. Some codes require 30-40 starts to clear while I think there may be some that might clear the next cycle. If its gone then :highfive:.
1 - 11 of 11 Posts
