1 - 2 of 2 Posts
1990 Allante
I have just finished replacing the front motor mount on my 1990 Allante. Now the car seems to pull slightly to the left and is making a distinct humming noise which is worse when turning to the right. Could I have misaligned the Engine/Transmission when replacing the mount. Is it possible I could have damaged the CV joint when I jacked up the Engine? Any help would be greatly appreciated.
did this once... 86 Deville, 86 300E, 78 R100rs
It is unlikely that your engine is out of line, as the holes to assemble do not have much leeway, and I suspect you didn't loosen the others to replace the bad one....
It IS possible that the CVs took a hit, but that would most likely be only from the INSIDE tri-pot joint, and you would have to lift that assembly WAY HIGH to overreach them.... although you might have...
1 - 2 of 2 Posts
