Motor builders
2167 Views 24 Replies 9 Participants Last post by  thebigjimsho
Okay fellas, you have the king of the hill cars, but do you have the cool motor builder tag on your engines that us STSv guys have? If so, where is it located and who was your builder?
First one to find and post a pic will get a prize from CadillacForums.com
F
1 - 20 of 25 Posts
Sorry F, but the LSA isn't built by one person like the LC3 in the STS-V.
Hmm, I didn't know that about the STS-V.
The only tag on the new CTS-V engine that I see is the GM Performance Division tag at the front.
thats the GMPD sticker...the guy that actually built our motor puts a personalized sticker on the STSv motor.
F
that surprises me with the low volume of blown 6.2L motors....you sure about that? They arent made in Wixom?
F
^^^ Nope - I read somewhere that the blown v2 LSA's are built somewhere in Mexico. Not sure of the exact place in Mexico though ... ?
Rob
thats a drag.....
Ill just have to keep this prize hat then.
F
OH SNAP!!!! In the end it's still just a chevy motor? That's a damn shame.... Looks like we STS-V owners get to keep our tag line Most powerful CADILLAC ever produced.... :) :)
Built in MEXICO? Is that where Chevy engines (and apparently ours) are assembled nowadays? I had no idea, I assumed that they were built here. At least I helped keep the LGR assembly line workers on the job by purchasing a V......
trudat! Sux for the CTSv guys.
F
Yeah, you can even buy an LSA marine crate motor.
I suppose a builder plate is nice, but think of it this way: 556HP isn't even special enough to justify it now.
Here is the full spec .pdf on the marine engine if anyone is interested. I had no idea it existed until now...
http://www.gm.com/experience/techno...s/specialized/marine/2010_6200_LSA_Marine.pdf
Unfortunately, it's still the 2nd fastest...
From the site you quoted above, the CTS-V's engine is built in the Silao, Mexico plant that builds the marine engine and several Chevy truck models. Interesting to know. Here's the full specs from the GM site listed below.
http://media.gm.com/us/powertrain/en/product_services/2009/09car.htm#62L
2009 "LSA" 6.2L V-8 ( LSA ) 60908
Type: 6.2L Gen IV V-8 Small Block
Displacement: 6162cc (376 ci)
Compression ratio: 9.1:1
Valve configuration: overhead valves (2 valves per cylinder)
Assembly site: Silao, MX
Valve lifters: hydraulic roller
Firing order: 1 - 8 - 7 - 2 - 6 - 5 - 4 - 3
Bore x stroke: 103.25 x 92mm
Fuel system: sequential fuel injection
Fuel Type: premium required
Fuel shut off: 6200 RPM
Emissions controls: catalytic converter
three-way catalyst
positive crankcase ventilation
Engine Orientation Longitudinal
Valves per cylinder 2
Bore Center (mm) 111.76
Applications: Horsepower: hp ( kw )
Cadillac CTS 556 hp ( 415 kW ) @ 6100 rpm SAE CERTIFIED
Applications: Torque: lb-ft ( Nm )
Cadillac CTS 551 lb-ft ( 747 Nm ) @ 3800 rpm SAE CERTIFIED
MATERIALS
Block: Cast aluminum
Cylinder head: A356-T6 rotocast cast aluminum
Intake manifold: Cast aluminum
Exhaust manifold: High silicon / high moly cast iron
Main bearing caps: Nodular Iron
Crankshaft: Forged steel
Camshaft: hollow steel
Connecting rods: forged powder metal
Additional features: 1.9 L/rev Supercharger
Integrated single coolant to air intercooler
Piston oil spray cooling
Direct mount ignition coils
more likely the third.....
theres no replacement for displacement...
(just ask your chair, right TBJS???)
F
F
I'm talking model lines. Wait, an XLR-V would be faster too, I guess...
no??
1 - 20 of 25 Posts
