My 2008 DTS (FE1 suspension) with 94K miles on it has a bad strut bearings (I believe that's the problem). When standing still, turning the steering wheel back/forth a little bit results in a clunking sound from the passenger-side spring ... and you can see/feel the spring "popping" if you're outside looking at it. The sound also happens going up/down over bumps at low speeds.
The Buick dealership wants $1200+ to replace the struts -- $200 each for the struts, $200 each for the top plate, plus labor, alignment and I'm sure I've missed some parts in there somewhere. I'm quite sure the Cadillac dealership would want more.
I can get the Monroe Quick Struts for about $185 each at the local auto parts store. It looks to be a straight-forward job that I can do myself; saving about $800. However, I've not heard the best things about the Monroe Quick Struts. Everything from harsh ride to creaking/clunking/rattling noises to premature wear ... has been mentioned. But my research has only really given me info about other cars and not the DTS.
I'm sure that I could get AC Delco struts cheaper than the dealership's quote, but they don't have a quick strut available. I can order all parts (including springs and ancillaries) from GM Direct for less than $400/side, but I don't know that I would know how (or have the tools) to properly put it all together ... and install them without creaking/noisy results.
I want the softest ride possible and have heard ... 1) that AC Delco is softer than Monroe ... and ... 2) that AC Delco is a re-labeled Monroe and that there's no difference between the pair.
Quite honestly, I'd rather not even bother ... I could live with the noise ... it's not that loud ... and I don't want to mess with the ride. But the dealership said that the faulty strut bearings are partially to blame for my premature tire wear. My tires are new (bought in July and have about 2K miles on them and are already starting to wear on the outside edges). The dealership just replaced my front wheel bearings ... to the tune of $800 ... but I was told they were very bad. Oddly enough, the noise from the struts quieted down after the wheel bearings were replaced. It's still there, but not as loud.
I'm weighing my options and have done a lot of research ... but not much is said about the DTS and how people have felt about the quick struts after installing them on their DTS.
Thanks in advance.
Thanks in advance.
