Rob,
I will have the new module on Monday evening. I was going to only do the turns signal frequency doubler, but by the way you describe it above it sounds like both mods may be the way to go. So if i understand you correctly by doing both mods with the "pin H (i think)" on the module for the DRL and cutting the flasher resistor on the board, both items will function properly yet independantly? The DRLs will come on automatically based upon ambient outdoor light, and off accordingly, and the turns will not hyper-flash as if a bulb is burnt?
Can you tell what "points" to disable each? is this the one for the DRLS?
http://cadillacfaq.com/faq/answers/disdrl/index.html
Is this the correct point for the hyper flashing - bulb out?
The beginning of this thread? Does the 0.03 ohm resistor only need seperated on one side to break the circuit, or need to be completely removed? If removed does a straight connection need made for circuit continuity minus the resistor?
Did you see my post about the "1 LED away...." I have an odd polarity issue I think that I will be unable to resolve between regarding the turns signal LEDs and and anything more than parking lights turned on. With no lights on the turns work, once the parking lights or more are turned on only the front side markers do not come on... odd. New HID fogs seem to dim the front amber DRL LEDs. Maybe it is a washout, or current draw. DRLS on only they are BRIGHT for LED, but seem dimmer once fogs are lit.
This is equally fun as frustrating..
