Mobil 1 0W-40 GM DEXOS R
1 reading
10K views 41 replies 17 participants last post by  Submariner409
Can I use Mobil 1 0W-40 GM DEXOS R
On my atsv 2016. I am not sure if we can use dexos r. Please advise. I live in warm to hot weather and run the car hard.
Moderator edit: Posts merged into this OP thread from identical dead thread. Sub.
#3 ·
I've been wondering about a 0W40, too. The LF4 does not have cylinder deac. so my guess is going to a 0W40 is ok. I run a 0W40 in some of my V8 engines. I like it because the 0W gets to bearings quicker on cold starts. I'm wondering if a high-end, ester-based, 0W40, like Red Line, would allow me to use the same oil for normal street driving and maybe some tracking.
#12 ·
Mobil 1™ Supercar 0W-40 is an advanced full synthetic motor oil specifically designed for high performance cars to provide exceptional cleaning power and wear protection, and deliver outstanding overall performance. Mobil 1™ Supercar 0W-40 is proven in high performance North American sports cars and suitable for use in everyday driving and high performance track events.
From street to track, Mobil 1™ Supercar 0W-40 has been expertly engineered to help prolong the life and maintain the efficiency of emission systems in gasoline powered automobiles. We're as passionate about your engine as you are about your car.
  • Meets dexos® R specifications and can be used in place of dexos® 2 in all GM high-performance gasoline engines
  • Mobil 1™ Supercar 0W-40 (126870) has replaced Mobil 1™ ESP Formula 0W-40 (123875) in 2022
  • Mobil 1™ Supercar 0W-40 is made with a proprietary blend of leading edge components formulated to provide outstanding performance in many driving situations.
  • Single oil for street and track use
  • Holds the distinction of being the first and only dexos® approved motor oil developed specifically for Corvette
  • Enhanced frictional properties help enable improved fuel economy, higher horsepower and reduced engine wear
  • Active cleaning agents help enable lower operating temperatures and longer engine life
  • Outstanding thermal and oxidation stability help to reduce oil aging
  • Excellent aeration control
  • Catalytic converter compatibility
  • Sold as a case including six 1 quart bottles
#19 · (Edited)
M1 0W40 ESP was renamed to 0W40 Supercar, so it will be the Supercar branding going forwards and not the ESP labeling.
Tadge Juechter (Corvette chief engineer) did say they recommended using 15W50 for track days on the Corvettes and the ZL1 1LE over the factory M1 ESP/Supercar 0W40 as they liked the additional stability and lubricating properties of the 15W50 over the 0W40 at the high oil temps seen during track use, but he also said they did not test and validate the 15W50 for street use or long term emissions system compatibility (mostly the impact on catalyst life with the higher levels of ash/ZDDP/phosphorus.) He did say the higher weight of the 15W50 would marginally impact fuel mileage if you ran it constantly. The thread regarding oil use for track days is on Corvette Forum and comes up with a simple google search if you want to read Tadge's reply.
I agree the 0W40 Dexos 2/R oil should work great in these cars and does offer flow advantages with the 0w, especially at lower temps. When I do the break in oil & filter change on my new CT4-BW I'll probably switch to the 0W40 Supercar since it's a GM factory fill for the LT4 & LT1 from 2019-up and also Dexos-R approved, so I'm really not worried about lubricating properties, corrosion prevention, or LSPI issues.
FYI, I have seen dealers use incorrect grades of oils in customer cars if they're out of what is required. My local Chevy dealer was using Mobil 1 5W30 in the new Corvettes for a while even though they're supposed to use Mobil 1 0W40 ESP/Supercar because the 0W40 was unavailable for quite a while and they couldn't get enough of it.
The Mobil 1 ESP X3 0W40 (originally developed for Porsche) would be a good choice too as it's also Dexos 2 approved.
#22 ·
Not sure if it’s just subliminal, but my son’s SS drives incredibly smoothly after the service and new super car oil. Seems to drive better than ever. My wife and I took it on a weekend getaway while the boy’s back at college. Not sure how he felt about that! [emoji3]
#28 ·
Here's what I got from AMSOIL. I disagree with them on a couple of points (e.g. using 5W-30 all year round--I'm switching to 0W-30 or 0W-40 for extreme cold). If their ZDDP additive is not intended for Signature Series I don't know where they want us to use it. I asked them that question. I also put a question out to Redline along the same lines.
#38 · (Edited)
Keep in mind the LF4 was probably tested and validated with 5w-30 for lubrication properties and emissions system longevity way back in 2013/2014 during development prior to the release of the MY 2016 ATS-V, and the lubrication testing program for the LF4 was probably a derivative of the validation testing maybe even as far back as 2012 for the MY2014 Vsport cars with the LF3... I don't think Mobil 1 0w40 ESP/Supercar was even available at that time for them to consider and test, even if it is a superior oil and would have been a better oil to use in the LF3/LF4 than 5w30.
M1 0w40 ESP/Supercar being a much newer formulation is probably a superior oil compared to the older 5w30, especially since GM is currently using it in 2 of the 3 highest performing engines they make, the LT2 and the LT4 (the LT6 in the new C8 Z06 is using M1 5w50.) 0w40 ESP/Supercar may very well be totally appropriate to use and perform even better than than 5w30 in the LF4, but we'll probably never get an official confirmation/recommendation from GM for that as it just doesn't make financial sense for them to run a new oil testing and validation program on an limited production engine near the end of its production cycle.
If you want to play it 100% safe as originally designed, stick with the OEM fill of M1 5w30, but I don't think the M1 0w40 ESP/Supercar is going to hurt anything... it might actually perform better, but we'll probably never get an official recommendation from GM to use it.
I should probably ask my buddy in GM Powertrain development to dig around and see if there were any changes made to the bearing clearances, piston to bore clearance, or piston rings when they switched from 5w30 to 0w40 oil...
#41 ·
Tapout recommends the M1 Supercar oil for their Brown Belt cars; I was switched to that oil when my car was there. Prior to that, I ran Penzoil Ultra Platinum 05w-30. Before that, I used the factory recommended oil while I had the oil changes covered. At 40K+ miles, Tapout noticed I still had the cross hatching in the cylinder walls, so I can only assume that the AC Delco oil and then the Penzoil oil treated the car well. The car has been driven pretty hard in varying climates over it's life and has been maintained well. I can only assume that the 0w-40 will offer the same, if not a little better protection with the extra additives.
I have noticed that the car runs a little cooler, it takes a bit longer to get to operating temp and the oil temp cools off a little quicker it seems. I also have maybe 2 oil changes a year, so the extra cost for the 0w-40 isn't such a big deal. I'm sure it's fine for stock turbo cars too, but I'm not sure it's necessary.
