I thought one of the husbandly duties was keeping the wife's car full of gas.
It DEFINITELY is supposed to alert you BEFORE "LOW RANGE" appears on the DTE.Has anyone else with an 06/07 DTS noticed that there's no LOW FUEL alert message on their cars? On my car, even with the car's gas gauge as low as it will go and with the range display showing "LOW RANGE" there's no "LOW FUEL" message like I've seen on other Cadillacs. The manual says such a message exists, along with a picture of a gas pump. I hate to keep going with fuel this low just to see if the message eventually appears, but I wonder if this is something common to these cars or if there's just something different about mine. On my wife's 03 DTS, with the needle a bit above the E and with about 60 miles left on the range display, there is a tone and the "LOW FUEL" message appears on the dot-matrix display, but I have yet to see anything on my 06 DTS in the 6 months in which I've had the car. I'm concerned if my wife drives my car without this tone & message she might not notice the tank running out. Thanks! Doug
Same thing on my '06 DTS. I have run it pretty low a couple of times, and no LOW FUEL warning either. A few times on the DTE it was less than 30 miles. No chimes... no warning message.... in fact NO NOTHING. Thanks for reminding me. I need to talk to my dealer about that.Has anyone else with an 06/07 DTS noticed that there's no LOW FUEL alert message on their cars? On my car, even with the car's gas gauge as low as it will go and with the range display showing "LOW RANGE" there's no "LOW FUEL" message like I've seen on other Cadillacs. The manual says such a message exists, along with a picture of a gas pump. I hate to keep going with fuel this low just to see if the message eventually appears, but I wonder if this is something common to these cars or if there's just something different about mine. On my wife's 03 DTS, with the needle a bit above the E and with about 60 miles left on the range display, there is a tone and the "LOW FUEL" message appears on the dot-matrix display, but I have yet to see anything on my 06 DTS in the 6 months in which I've had the car. I'm concerned if my wife drives my car without this tone & message she might not notice the tank running out. Thanks! Doug
Dont do that. Its obvious to me its not working right and even if it is, you are FAR too close to the bottom for that to be right. Another SRX scenario involves a guy who was also using the "gallons used" on the DIC and ended up with a 3 gallon difference when he ran out of gas. Youre ALREADY closer than that and you risk burning your fuel pump or causing other damage if the thing goes completely dry. Damage which the dealer may not find to be in concordance with your factory warranty, even if for the sake of "research purposes".In an effort to see if I suffer this same problem on my 06 DTS I have used 16.7 gallons of the 18.5 gallon tank since filling up. DIC says LOW RANGE if I scroll to that part of the display but no warning whatsoever. Owners manual says that I should get a warning light and a chime for low fuel. Drove three Olds 98's and two park aves prior to this caddy. They shared a number of GM components and they always chimed in or had warning lights when I had about three gallons left in the 18 gallon tanks.
My gas needle is dead on the bottom hash mark of the analog gauge if not a hair below. My DIC usually registers pretty close to how much gas I pump. If it says I used 16.7 then I expect when I fill it up I will be within a couple tenths of a gallon accurate assuming the gas pump is accurate at the station.
I am goign to drive it till I have about a gallon and a half according to the DIC to see if the blooming thing works. I'm almost there now.
Mine didn't come on till I was a tenth of gallon beyond that, or right at 17 gallons used. I would agree however that this is not how it should be although it may be a design issue rather than a faulty component. By the way, the tank is published at 18.5 gallons capacity. (versus 18)I put 16.9 gallons in the 18 gallon tank in my '06 DTS a few days ago.
The low fuel warning "NEVER" came on. The miles to empty showed 38. On some of the other Cadillacs I have had, the fuel warning would come on at 50 miles to empty.
I think the dealer is going to get to work on this one.![]()
Jim
Book says pump pic shows up at 30 mi. Too close for comfort for me. I never let my gas get that low. For those of you that insist on finding out, bring a gas can from your lawn mower with you ( with gas in it), and if you run out, you are at least prepared. ( 4 cycle motor in lawnmower of course!)
