1 - 10 of 10 Posts
2008 DTS base
Hey everyone been searching a little and can't seem to find another person with my "same" issue. So about a week ago my car started to misfire so i had the codes pulled and it came out with P0300 P0302 P0202 so i understand that cylinder#2 is misfiring and someone suggested its a coil which ive replaced on another cylinder already to stop a misfire last month. This time around it seems different because the misfire all of a sudden disappeared for about a week no lights no shaking, until last night when i started my car. Gonna try n get a better look today after work just wanted to see if anyone has had a similar situation with it just going away and coming back.
Btw my car is an 08 base model with about 147k miles. Thanks in advance
2011 DTS Premium w/1SD | 1999 Deville Base (RIP @179K Miles)
Were the spark plugs ever changed, The ones that came with the car wear out after 100k miles
2006 DTS
I replaced my #2 coil beginning of January. 2006 luxuryII DTS with 128,000. it cleared up for 1 day then stared back finally going from TCS system failure to this #2 crap again. My codes are #2 misfire & coil again. I found a link in January that I didn't save. Looking for it now. Deals with some guys exact same trbls as ours. His 4th time he went to a 3rd dealership & they found something else as root cause of the "exact same cylinder misfire" trbls he kept having. I'll hit back when I find it. $45 each time gets old superquick.,, & its not a part "brand or quality" issue either.
$5 spark plug gapped correctly, already changed & is intact & functioning as manufactured:yup:
2008 DTS base
wish i had been able to get back on here and read that beforehand i used the bwd brand before and same yesterday and replaced my front 4 plugs with some motorcraft plugs seems to be running good so far but i will keep my fingers crossed. the old plugs looked to be in pretty bad shape and kinda burnt out. and on another note i had a small buildup of oil in my #8 hole hope that doesnt affect anything for awhile.
The plug wells are sealed by O-rings in the cam cover which weep over time. Oil on one or more Northstar plugs is very common. Not a problem.
As advised, install the correct AC Delco Professional Platinum plugs. They come pre-gapped to .050". Use a tad of anti-seize on the first 3 threads and torque to about 13 lb/ft.
2008 DTS base
Might have to switch plugs misfire cane back after driving 30 miles to work today but it was fineon the way up here until I turned it back on afterwards. Or could it be because I didn't torque them
2008 DTS base
Discussion Starter #9
the only code that its throwing right now is that my circuit to my injector is bad so ill have too do some searching and get that part next
The actual torque is not that critical - but I use the figure as advice they need to be securely tightened as opposed to a lick and a promise.
........... and an improperly tightened plug can overheat and burn off the electrodes - that thread-to-head contact is one of the things that determines the heat transfer rate (heat range) of a given plug.
1 - 10 of 10 Posts
