2007 1SG STS v8 awd
I recently changed my o2 sensor. Engine light is off but I still have hesitation and a misfire under heavy acceleration or under load. I. Thought the o2 sensor was causing this. If I accelerate hard the engine light would flash along with the tc light coming on. It would then both go off. What could possibly be causing a misfire under load/acceleration? And not throwing any codes setting off the engine light. If the light would come on I would have somewhere to start.
2005 cadillac STS AWD 1SG
DTC should be in memory even if check light doesn't lit. So check for DTC first.
Spark plugs and coils are the main reason that could be.
2007 STS-V
If the O2 sensor was bad, you could have been running rich for some time causing plug fouling. You probably need to reset the computer with a battery disconnect and new plugs. Changing the sensor just gets it back within correct mixture rating, it does not clean the plugs from running too rich.
05 STS 1SG v8 RWD
just a thought, but.
when you said TC light coming on did you mean Traction control?
if so, you could have something wrong with your traction control system, you said that this is happening under heavy acceleration. I know my car will spin if I step on it.
if your tires are loosing grip and there is an issue with the traction control then this could be causing the hesitation.
also if the wrong signal is being sent to the engine then this would cause the engine light to flash.
2007 1SG STS v8 awd
It's not wheel spin at all. The tc light just comes on when the engine light is flashing that's all. And the engine light finally came on giving me a code p0300 random misfire. What the hell could it bed now. All the 02 sensor codes are gone but now this. Where do I start. Coils, plugs, fuel injectors what. It is possible I fouled the plugs so I may start there. Even though I just changed the plugs last year.
2005 STS4
I dumped tons of $ in my sts4 trying to figure out a misfire. Took it the the stealer where I spent around $500, but ended up being a short in a wire coming from an injector. Had to run new wires from there to the ecu.
2007 1SG STS v8 awd
Discussion Starter · #7 ·
. Who found the issue and how did they find it. A random misfire code sucks cause it's like a guessing ?game
B1n2fra said:
. Who found the issue and how did they find it. A random misfire code sucks cause it's like a guessing game
